What caused this staining on a Junghans Dial?
Discussion in 'General Clock Discussions' started by Mark SA, Jun 17, 2018.
  1. Mark SA
    Mark SA Registered User
    Nov 28, 2012
    486
    HIV Educator and Business Owner.
    South Africa
    I have started cleaning a Junghans box Clock from about the 1920's there are what appear to be stains or marks on the dial.
    I have seen this kind of staining before, on other clocks.
    I am aware that aggressive cleaners can remove the numbers, and metal finish.
    Were these dials anodized or plated?
    Would a slightly acidic solution work?
    Vinegar or lemon juice mixed with distilled water?
    I wonder if this is not perhaps nicotine or oil from peoples hand that has caused the problem.
    Attempt a light clean or leave as is?
  2. Chris Radano
    Chris Radano Registered User
    Feb 18, 2004
    3,449
    156
    Pennsylvania
    On aged silvered dials, I use cream of tartar, or potassium bitartrate. The same cream of tartar that may be in your kitchen's spice cabinet.
    Mix a teaspoon of two with a small amount of water in a small container. Stir into a paste. Wet the dial with water. Then use a rag wet with water to apply the paste on the dial. Use moderate pressure to rub the dial with the wet rag and cream of tartar paste. You will see the dirt come off the dial.
    Then after cleaning, rinse the dial with water and gently pat dry with a towel.
    After dry, apply a quality paste wax on the dial. I use Renaissance, or Behlen's blue label wax.
    It's a gentle way to clean the dial, and should be relatively safe. You may find some of the silver is already worn, but it will remove the dirt. And the dial will remain original.
    Mark SA likes this.
  3. Mark SA
    Nov 28, 2012
    486
    South Africa
    Thank you Chris. This is most helpful.
  4. Willie X
    Willie X Registered User
    11,985
    690
    Mark,
    Keep your fingers crossed. You never know exactly what will happen when you attempt to 'ole dial cleaning thing'. You probably can guess how I know this. Just a warning that you need to be prepared for both the better and also the worse ...
    Note, there are at least two different types of "cream of tarter".
  5. Chris Radano
    Feb 18, 2004
    3,449
    156
    Pennsylvania
    Always do a test on a small, inconspicuous area before attempting a more widespread cleaning application.
  6. gleber
    gleber Registered User
    Jun 15, 2015
    1,568
    157
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    That's helpful Willie, but are you going to leave us hanging like that? I'm glad I'm not on a bomb squad with you... "See the two wires?" "Yes, I got 'em." "Okay, good, cut the different one..."
    :confused:
  7. Willie X
    11,985
    690
    Tom,
    I don't know what the practical differences are but one is based on a Potassium molecule and the other on an Ammonia molecule.
    MacGyver :)
  8. claussclocks
    claussclocks Registered User
    Mar 14, 2013
    719
    178
    Texas
    I did a little quick reading and it appears the potassium version might be the better for clock uses and is the more common found in kitchen cabinets. In case you did not know, ( I didn't) it is a precipitate by-product from wine fermentation. Recommended usage is mixing with vinegar or lemon juice. The ammonium based version appears a little more aggressive. Not ready to chisel this in stone, so if anyone has further insight please share. However, as cautioned above, test in a inconspicuous area or on a salvage piece first.
  9. Ralph B
    Ralph B Registered User
    Nov 25, 2006
    579
    10
    Napier, New Zealand
    As the numerals appear to be printed on the dial, and not engraved, I'd go carefully when using anything that was even mildly abrasive near them.
    I've found some old printed numerals to be a little fragile/flaky.
    Mark SA likes this.
  10. dAz57
    dAz57 Registered User
    Dec 7, 2011
    2,018
    watchmaker
    sydney Australia
    #10 dAz57, Jun 18, 2018
    Photograph and photocopy the dial before you do anything, and be prepared to reink the dial because you will not get matching fonts.
    The dial isn't that bad, I would wipe over a soft cloth with Coleman's fuel to remove any old oil and grease and then leave it alone.
    What you have is thin lacquer applied over printed numerals, go through the lacquer and the numbers will come off, as it is the dial is in good condition, the printing is clear and not rubbed off.
    I will repeat, any attempt to clean this will make it worst, leave it alone.
    Mark SA likes this.
  11. claussclocks
    Mar 14, 2013
    719
    178
    Texas
    Sounds like good conservative advice to me. You could end up with a faceless clock
  12. Willie X
    11,985
    690
    Yep, some dials are silk screened with water soluble paint. I'm talking about (sometimes) very soluble paint.
  13. gleber
    Jun 15, 2015
    1,568
    157
    Does anyone know if there is/was a reason to use water soluble paint/ ink? Seems shortsighted to me.
    Tom
  14. claussclocks
    Mar 14, 2013
    719
    178
    Texas
    Too early for EPA and others to get involved like they did with water based auto paints in early 80's. After a few years it looked like you painted your car with Tempra paint. My guess would be, easily available, inexpensive, and looked good when it was put on. After all, how many of these people would have guessed we'd still be keeping and fixing these clocks after almost a century.
  15. Mark SA
    Nov 28, 2012
    486
    South Africa
    Thank you Willie
  16. Mark SA
    Nov 28, 2012
    486
    South Africa
    Will do Chris. Thank you.
