What cameras do you use for closeup watch/clock photos?
Discussion in 'Horological Tools' started by Firegriff, Mar 17, 2014.
  1. Firegriff
    Firegriff Registered User
    Feb 22, 2013
    756
    I have a spare Nikon D40 digital SLR body with a 18-55 mm standard lens and would like to use it for taking close-up photos of watches for archiving repairs and for sharing. I originally bought to mount on my 3x90 tri-ocular Amscope inspection microscope but it magnifies to much and I cannot get sharp focus on a entire watch works great otherwise for close up of sections of watches or tiny parts but not for the whole watch. The standard lens works ok but wont focus properly on a close up of a entire watch (To far away). I know the answer may lay in a MACRO lens but I am not sure what type would work properly. Would anybody have any suggestions?.
  2. Thomas Hammond
    Thomas Hammond Registered User
    Apr 17, 2010
    37
    I bought the AFS Micro-Nikkor 40 mm f/2.8 lens about a year ago, and use it almost continually on my Nikon D90 for general shop photography, including close-ups to roughly 1:1. I mostly use in in fully-manual mode, but the autofocus is surprisingly good for many applications. I paid about $250 for it; good value in my opinion.
    I also have the (much) older 55 mm and 105 mm Micro-Nikkor lenses from my film photography days; they also work well on the D90, but of course are manual only.
    Hope this helps,
    Tom
  3. Firegriff
    Feb 22, 2013
    756
    Thank you that was what I was looking for it is still that price on Amazon.
  4. emhitch
    emhitch Registered User
    Mar 17, 2009
    97
    medical device design engineer
    pittsburgh, pa
    Firegriff, I use a Nikon D50 SLR body with a Nikon 105 mm f/2.8 FX AF MICRO-NIKKOR (1990-2007 version) for extreme close up work in addition to the AF-S DX VR Zoom-NIKKOR 18-200 mm f/3.5-5.6G IF-ED. Between these two lenses, I have been extremely satisfied with my results. The 105 mm lens is a true professional lens and, although I am far from a professional, I can clearly see the difference when using this lens. Hopes this helps.
  5. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    683
    64
    Tulsa, OK
    I have had pretty good luck with a set of close-up lens filters similar to these. Make sure to get the size to fit your existing lens. Much less expensive than a new lens, but probably not nearly as high quality. Good enough for what I need.
  6. Joe Collins
    Joe Collins Registered User
    Jan 3, 2004
    986
    Good cameras can be found in unusual places. Take for example the Toshiba Camileo x 400 Series video camera. While it is primarily a video it can take some outstanding stills. The wide macro mode focal range is 1 cm, (.390") to 120 cm, (47.24"). In the normal mode the focal range is 1 cm to infinity.
    This picture of a 12 size South Bend Studebaker was taken with available light just to show how close it would focus. It has not had any cropping.
  7. James Foster
    James Foster Registered User
    Dec 13, 2010
    132
    13
    Clockmaker @ Your Time Clock Repair
    East TN
    I use an iPad mini to capture and view images. I also use it to populate a spreadsheet template documenting the condition of all timepieces coming into my shop and as an interface with Quickbooks online creating invoices and taking credit card payments. The images are certainly good enough for my purposes and I get a lot of value for the small amount of space the iPad takes up. This is an example under fluorescent light which is not particularly friendly for image capture.
  8. David S
    David S Registered User
    Dec 18, 2011
    7,203
    248
    Brockville, On Canada
    Awesome photo Joe.
  9. Russel
    Russel Registered User
    Jul 15, 2013
    11
    I use and old Nikon D200 with a 60mm macro lens.
  10. glenhead
    glenhead Registered User
    Nov 15, 2009
    1,142
    173
    Telecom Engineer
    Williamson County, Texas
    I use a Canon PowerShot A590.
    It's a point-and-shoot style camera with retracting lens, and goes from full automatic to full manual. We bought it originally because it has a very good reputation for working with a spotting scope for wildlife photography. It works just as well with a microscope. I just hand-hold it to the ocular on either style of scope, and fiddle with the alignment until I have what I want. It has a surprisingly good macro capability on its own. There have been a couple of further generations of it since we bought it, with the same (or better) capabilities. The first three shots are taken with the macro setting on the camera, and the last two are through microscopes.
    Here's a shot of an 18s BW Raymond:
    On the other end of the scale for a complete movement, here's a Bulova 3AN:
    Here's a shot of the reverser wheel in an Omega 550. For reference, the kingswood block is 3/4" (2cm) across:
    Here's a shot through one of the oculars on my stereo microscope, showing the hack mechanism in an Elgin A-17A at 30x:
    Finally, here's a shot through my stage 'scope, showing a crunched jewel at 40x:
    Glen
  11. Steven Barnett
    Steven Barnett Registered User
    Oct 20, 2011
    37
    SF Bay Area, USA
  12. Steven Barnett
    Oct 20, 2011
    37
    SF Bay Area, USA
    Here's an example of a photo taken with a Nikon DSLR, 80mm prime lens, and an extension tube 2836-2HS ver 2.jpg
  13. Firegriff
    Feb 22, 2013
    756
    I am going to purchase the AFS Micro-Nikkor 40 mm f/2.8 lens for my D40
    it has a reasonable price.
  14. Firegriff
    Feb 22, 2013
    756
    You can get some nice DSLR's for a fraction of their original cost the one I purchased Nikon D-40 off e-bay can with a good battery and charger but no lens for $60.00. I tried the lens that came with my D-40x and it worked just and when used with the adapter on my microscope took great pictures but I could not get a 18s watch movement completely in the picture it did great for shots of jewels and other small fine parts. So with the 40mm lens and a short tripod it should work one plus is that the Adjustable LED light ring that came with the microscope fits the lens so it lights the subject well with no shadows and it will adjust brightness to reduce glare in the shiny movements and cases. I may also get one of those octopi arm mounts on a small tripod for close-ups as I wish to take component parts of the watch as I dismantle them. I do still kick my self for not getting a boom mount scope would have made lathe work easier with my old eyes. The scope is a AmScope try ocular 3x90 inspection type and works great for hair spring and pivot holes or any other microscopic parts this will be a dedicated setup because I do not plan to use the camera for other types photography.
  15. R.G.B.
    R.G.B. Registered User
    Feb 27, 2009
    665
    Photographer
    Vancouver B.C.
    Be aware also that most lenses sold have macro listed but aren't true 1:1 lenses. I have older rail systems but currently use extension tubes. Also use your aperture to get as much depth of field as you can squeeze
    out of the lens. F: 16 or higher is good to start. Diffraction at that distance isn't going to be noticable.
