• Upcoming updates
What am I missing?
skinnb1
Oct 4, 2015
84
I have a friend's clock which has had an accident and was not known to work previously. It never-the-less seems to be intact except that the suspension spring is broken and I can't see a way of attaching a replacement suspension spring. I have not yet dismantled the clock which appears to have a deadbeat escapement and no evidence of a maker's name, simply a serial number. Nothing appears to be broken. How was the suspension spring attached? Am I missing a suspension post or am I simply being dumb?
Thanks for any help you can give. 20221004_164806.jpg 20221004_164812.jpg 20221004_164832.jpg
5,773
987
Exactly. It is also possible that there is a post for the suspension spring mounted directly to the case and not to the bracket. Just take a look at the back board of the case.
skinnb1
Oct 4, 2015
84
Thanks both. Being dumb I suppose. Of course I left the case with the friend because it needed some repair to the woodwork.
180,051
1,570,715
54,363
mickri
911
3,090
