To W it may concern,
I let the weights on my grandfather clock run out to the bottom of the case and when I pulled them back up the Westminsters chimes refused to function. The time piece is about thirty years old and has worked perfectlly before this incident. The chimes work perfect when I flip the toggle switch to test the chimes. Do you a solution to this problem. I would appreciate all positive assistance in assisting in this matter.
Thank you Mhaighitis
