Weights for Waterbury 57
Dlclocks
May 20, 2011
41
I have a Waterbury regulator # 57 without weights. Does anyone know the correct size and weight for these weights?
Thank you David Leinen
owen.or
Aug 26, 2000
1,212
45
Near Portland, Oregon
David, I have a Waterbury #67 which I believe uses a different style of weight from the #57; however, the movement is likely the same so the weight of the weights is probably the same. I used a bath scale which gives an approximate number. My scale indicates they weigh between 4 and 5 pounds each. David, owen.or
176,432
1,544,324
53,306
Boriss_k
1,064
3,031
