Weight of WW clock movement
Discussion in 'Wood Movement Clocks' started by Frank Smallman, Oct 14, 2016.
  1. Frank Smallman
    Frank Smallman Registered User
    Nov 28, 2010
    If you don't know the name of the movement; how do you determine the correct weight of the time and strike trains. I'm guessing it has to be 5 lbs or greater. Any info will be appreciated.
  2. gilbert
    gilbert Registered User
    Aug 25, 2009
    432
    30 hour clock?
  3. Jerome collector
    Jerome collector Registered User
    NAWCC Fellow NAWCC Member
    Sep 4, 2005
    828
    61
    Geologist, US Army Corps of Engineers
    Omaha, NE
    Frank,
    It would help greatly if you could post pictures of the movement.
    Mike
  4. R. Croswell
    R. Croswell Registered User
    10,211
    821
    As others have said, a picture of your clock movement would be a great help. Lacking any additional information, a 30 hour movement with weight cord over just one pulley at the top of the clock will typically have about 3 to 3 1/2 lb. weight but may run with as little as 2 lb. if it is in perfect condition. A typical 8-day movement will likely have a compounded weight system with a pulley at the top of the clock and a pulley at the weight. Such a clock will probably want 8 to 12 lbs. weight and the strike side may or may not be the same as the time side. There are two easy ways to determine what the clock actually requires IF THE CLOCK IS KNOWN TO BE IN GOOD ORDER: 1) start with a weight that is too light and gradually increase until the clock runs well. 2) pull on the weight hook with a fish scale until you pull enough force to run the clock. If you can anchor the fish scale, then just wind the clock against the scale until there is enough force to run the clock. When it stops, read the scale and you will know that you probably need a pound or so more.
  5. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,823
    565
    Magnolia, TX
    As Mike suggests we need to know what clock you have. Depending on the maker, and if it is 30 hr or 8 day, the right weight could be as little 2.75 pounds or as much as 11 or 12 pounds. And in some clocks time side and strike side have different weight weights.....not to be repetitious or anything.
