Webster vs Ollie Baker Mainspring Winder
Ramsey Badawi
Oct 4, 2021
49
55
Hello
I am a newbie in clock maintenance and repair and could use some advice on mainspring winders. I have a loop end mainspring winder which I am currently using with some trepidation - and it looks to me like it won't always do the job for all spring designs.
Everything I have read or watched on youtube says the Ollie Baker is the one to get. However, it seems the Ollie Baker cannot be had for love nor money these days - but Websters are available. I lack the experience to know if I should hold out (for an indeterminate amount of time) for an Ollie Baker, or whether it makes sense to go with a Webster ...
All advice gratefully received!
- Ramsey
15,633
2,137
I've used a Webster for about 30 years in a small but busy commercial setting.
I like it. I think the tail stock is standard now? If not, be sure to get that.
Ramsey Badawi
Oct 4, 2021
49
55
Many thanks, Willie!
This is what I am looking at - looks like it has a tailstock to me - is this what you meant?
15,633
2,137
Yes, you need all that. I don't like the new plastic handle but it would be easy enough to make a steel one. Willie X
Mike Mall
Oct 27, 2021
93
26
Here's mine, made from an inexpensive bar clamp, and a cheap dual drive ratchet. I just use a socket to fit the let down tool chuck. Pretty stable, and the ratchet holds in either direction.
Bkeepr
Jul 8, 2020
33
7
Maryland
I bought a well-used Joe Collins winder on ebay. It is perfect. If it ever breaks, I will easily replace the wood parts with new wood and go for another 20 years. Not as pretty as a nice new machine, but it works just as well, and the price was far better.
Mike Mall
Oct 27, 2021
93
26
What do you use to clamp barrell springs? Do you have sleeves?
I use a hose clamp for barrels, I just put a hole in the end to hold the clamp. I'm a hobbyist/collector, I work on mostly loop end type. But if I started doing more of the barrel type, the stationary end of the winder could be easily modified. It's a one handed set up, (unless I'm changing direction). These are the cheap ratchet, and bar clamp I started with. I built a simple crank out of a 1/4" extension for the back side.
Reactions: wow
48,177
2,397
I also use the Webster in my shop and it does the job well. It requires the operator to hold the barrel himself, but that has never been a problem for me (and I'm old :))
wow
Jun 24, 2008
5,871
751
76
Pineville, La. (central La.)
That’s one of the features I like on my Ollie Baker. It has a special steel catch that is designed to hold a large barrell. It catches on the joint of a hose clamp. Mine is strong enough to handle Fusee barrels and Sonora chime barrels. I’ve never used a Webster so I can’t compare.
Reactions: lpbp and Kevin W.
171,031
1,493,244
50,083
3号缐
2,967
