Waterbury Verge Question
Discussion in 'Clock Repair' started by hookster, Dec 19, 2014.
  1. hookster
    hookster Registered User
    Jan 14, 2011
    1,998
    Pharmaceutical Consultant
    Pottageville Ontario Canada
    Someone brought me in a Waterbury yesterday. Check the picture. Isn't the verge the wrong way, in other words the pallets are reversed from what they should be. Has great swing, about two inches, but I am afraid that, over time, this might damage the escape wheel. I checked my Waterbury and the pallets are indeed the other way around on it. The owner doesn't know the history as he bought the Kitchen Clock at a Garage Sale. Other than this, the movement only needed external cleaning/oiling and beat setting, and seems to be running great. If my suspicion is correct, I'll have to get him the correct verge/crutch assembly.:confused: DSCN0320.jpg
  2. Steven Thornberry
    Jan 15, 2004
    21,236
    748
    Ne’er do well
    Here and there
    Assuming the EW moves CCW and that it is supposed to be a recoil escapement, something is installed incorrectly.
  3. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    64
    The wheel looks to turns CCW. The way it tips are pointed, it should
    have a strip deadbeat, not a recoil.
    If it was intended to be a recoil, the escapement is backwards.
    not the pallets.
  4. hookster
    Jan 14, 2011
    1,998
    That's what I thought. Thanks. I'll have to make him a new one. PS. My similar Waterbury has a recoil escapement.
  5. R. Croswell
    R. Croswell Registered User
    9,507
    603
    My Waterbury has the escape wheel the same way but it looks like your verge is just on the post upside down. Just put it on the other way and it should be fine. You may need to reform the crutch foot so the foot faces out.
  6. Tinker Dwight
    13,666
    64
    OK, Hookster, which way does the escapement wheel turn?
  7. hookster
    Jan 14, 2011
    1,998
    #7 hookster, Dec 19, 2014
    Clockwise. I have been fiddling to try to make a new one fit, but am not getting too far. Think I'll sleep on it and go at it again tomorrow.
  8. Tinker Dwight
    13,666
    64
    Then, that confirm what RC says, the pallets are backwards or flipped.
    TIinker Dwight
  9. R. Croswell
    9,507
    603
    This is about how that escapement should look. (Don't worry about the prick punched pivot hole, this was before restoration.)
  10. shutterbug
    41,133
    792
    You also have some damaged teeth that need attention, hookster. Probably damaged by the improperly placed verge.
  11. hookster
    Jan 14, 2011
    1,998
    Good possibility Shutt, but no damaged teeth. I checked that.
  12. Rob P.
    Rob P. Registered User
    Dec 19, 2011
    1,837
    106
    California
    Take the verge off and flip it around. The twist the crutch wire so the foot faces outward.
  13. shutterbug
    41,133
    792
    Maybe it's just the pic, but it sure looks like some tips are bent over.
  14. hookster
    Jan 14, 2011
    1,998
    Can't do as it puts the saddle on the wrong side and will jam on the suspension wire post.
  15. hookster
    Jan 14, 2011
    1,998
    #15 hookster, Dec 20, 2014
    Can't do, as it would put the saddle on the wrong side and the crutch wire would then not clear the center hand shaft. I hate fashioning new verge/crutch assemblies, as the ones you order never fit right and you always have to keep fiddling with the pallet angles and the depth until you get it right. Sometimes you get it right quickly, sometimes it proves to be very frustrating. And, altering the depth on these is not easy as the adjusting arm/rivet is usually very tightly affixed to the plate. Grrr...
  16. hookster
    Jan 14, 2011
    1,998
    Thanks for photo RC. It is the exact same movement with the steel plates and brass bushing inserts, likely made during WW1 when all the brass was used for bullet and shell casings. From your picture, I was able to fabricate a new proper verge/crutch assembly using the pallet angles and correct sized parts. I also tore the movement down and punched out the old retainer pin arm and replaced it with a new one and riveted it not so tight as the old one. Movement is now all back together and swinging away just fine.Nutjob
  17. R. Croswell
    9,507
    603
    That's great to know. One thing you may already know, or will need to know if you ever install pivot hole bushings in one of these, the brass "plugs" are not necessarily centered on the pivot hole. Best to just bush the "plugs" leaving them in place.
  18. hookster
    Jan 14, 2011
    1,998
    Yeah I noticed that. If one were to just knock out the plugs you would have real problems. So, bushing the brass plugs is for sure the way to go.
