Waterbury minute hand
neil johnson
New User
Jul 19, 2020
I have a Waterbury clock and the minute hand no longer fits the arbor as it’s dimensions have become to big and is sloppy , I would like ideas on how to repair please.
JTD
Sep 27, 2005
9,340
898
It would help to know more about the hand - a photo would be so good.
Does the hand have a collet or not? How did the hand hole become so enlarged that it no longer fits ? That's quite unusual.
Please let us have more details.
JTD
bruce linde
ADMIN / MODERATOR
9,546
1,604
oakland, ca.
clockhappy.com
Use a tight taper pin and hold the hand in place. They usually have play.
no… too much slop is too much slop… and with some clocks too tight a taper pin (or hand nut) will stop the clock. we need photos of the hand showing the hole and the end of the arbor… as big and clear as possible. it may need a new bushing, and you may be able to peen it back into shape (although i’ve never been very successful with that approach). you might also be able to solder a flattened (originally domed) hand washer w square hole in the back of the hand). kind of depends what’s there, which we can not yet see
Reactions: JTD
Calvin H. Huynh
Feb 6, 2020
1,734
266
15
Madison
www.youtube.com
All American movements usually have a few minutes of slop.
bruce linde
ADMIN / MODERATOR
9,546
1,604
oakland, ca.
clockhappy.com
good to know.... except i completely disagree. while a 'few' can be two, it's typically three... either way even two is too many. there might be that much slop before servicing but there shouldn't be after servicing.
and... i would caution against absolute pronouncements as if they're statements of fact. in my experience, the more experienced the person, the less likely they are to make absolute pronouncements as each situation is different. it's ok to generalize, but absolute statements are too easily proven wrong.
i am running over 50 clocks and only two have excessive play in the minute hands... and only because i haven't dealt with them yet.
YMMV
Reactions: JTD
47,841
2,295
Does the hand have a coned washer in front of it? That might be the issue. The slop in the hand is only an issue while setting the clock manually. It will stay in place with a hand washer after it's set until the next time you need to move it. Old hands are hard to find, so we learn to put up with some of the minor quirks. ;)
Reactions: Calvin H. Huynh
169,847
1,482,391
49,199
Onge
2,965
