Hi, as I am based in the UK you do not get the chance to see many Waterbury Clocks and was pleased to find a Waterbury mantel clock to add to my collection.
However, looking at the movement out of the clock I discovered a couple of things.
It looks like the clock has been worked on in the past and had some parts played about with.
From what I can see, this movement does not have a pendulum adjuster mechanism even though the clock face has the adjuster hole in the top. In fact, there is no adjuster bar and it looks like the adjuster plate on the back of the clock for the pendulum spring is fitted upside down and looking at one of the gears this seems to have been soldered quite heavily for some reason.
I also found the remains of what could be part of a broken lifter bar jammed in the clock but cannot see where this may have been originally attached and the gauge of the bar wire is much thinner to any of the others lifter bars used in the movement.
We then found a pallet which is very worn/broken and looks to have been soldered/repaired in the past.
Can any body help with any pointers or a diagram/manual to check out where the broken part could be from and if it is possible to get a replacement pallet as a unit for the clock.
Thanks for your help.
