Waterbury Click spring source
Discussion in 'Clock Repair' started by dashley, Jan 26, 2016.
  1. dashley
    dashley Registered User
    Apr 30, 2015
    139
    Tennesse
    Hi,
    I'm looking for a source for a Waterbury 8 day movement click "spring".
    This is my first Waterbury and I'm not sure if how to identify it other than the left foot of the frame has an 11 stamped into it.
    There's only a small piece of it left (2nd pic). There was another foot stuck in the wheel where the break is so the dimensions between the nibs is pretty accurate.
    I've emailed Timesavers and they have nothing like it. I've been searching the a lot web also.
    Would anyone know a source for these.
    Thank You
    -dan
  2. emhitch
    emhitch Registered User
    Mar 17, 2009
    97
    medical device design engineer
    pittsburgh, pa
    Hi Dan, I would contact David LaBounty at About Time Clockmaking. He has an extensive parts inventory. His website is here
    I will examine my inventory tonight as I may have a Waterbury click spring too
  3. shutterbug
    44,045
    1,322
    I you have an old mainspring laying around, you can make one from it. A Dremmel cutoff wheel makes it quick. The area between the tabs can be tricky, and a jewelers saw is good for that.
  4. dashley
    Apr 30, 2015
    139
    Tennesse
    @ emhitch Thank you for the link. I've emailed him. Really like that site to. Going to read those pdfs.
    @shutterbug Thank you for the mainspring tip. I actually have a couple of broken ones sitting around. Never thought to use that material for a spring Ha Duh.
    I was wondering where I could get stock from to make one HA HA and here it was just sitting around. I can cut one and the tabs shouldn't be a problem. Thanks Again.
    P.S. What does the number "11" stamped into the frame led mean? Is that a manufacture year or model number. ?
  5. David S
    David S Registered User
    Dec 18, 2011
    7,203
    248
    Brockville, On Canada
    I have also made them from hacksaw blades.
    David
  6. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    166
    deceased
    The number on the movement is most likely referring to pendulum length.
  7. R. Croswell
    R. Croswell Registered User
    10,586
    936
    If you make one be careful not to make it taller than the original. On most Waterburys there is not much clearance under the second wheel.
  8. dashley
    Apr 30, 2015
    139
    Tennesse
    Ta Da. Made it from the old main spring Shutterbug. Just have to feather the edges and tighten the corners up but it will work.
    Thank You
  9. shutterbug
    44,045
    1,322
    Looks good, dashley! :thumb:
  10. GregS
    GregS Registered User
    483
    14
    Machesney Park, Illinois
    Nicely done dashley! Good work!
  11. David S
    Dec 18, 2011
    7,203
    248
    Great job and you saved the shipping charges.
    David
  12. R. Croswell
    10,586
    936
    Looks good and the price was right. Make sure it's secure when pressed in place and that the click rivets are not loose.
