Waterbury #34 Double Dial Calendar
Discussion in 'General Clock Discussions' started by gre406, Sep 9, 2002.
  1. gre406
    gre406 Registered User
    Oct 6, 2001
    611
    Hello there Bob..Nice clock. Mine misses a day here and there but for the most part is pretty reliable..Sounds like it is hung-up..
    Move the clock hands until the calendar cam is right after the drop position..(Should be around 12midnight if set properly) Now try to lift the lever again and see if it changes. If not, pull the calendar hand and dial. By lifting the dropping the center weight you will see how the mechanism works.
    I will post photo of correct alignment if this doesn't help..Let me know..
    Geo
  2. gre406
    Oct 6, 2001
    611
    Bob ..Check this link..Its a Monster so you may read & print..
    http://userweb.nni.com/gre406/34-1.jpg
    I will post photos if this does not help.
    Geo
    [This message has been edited by gre406 (edited 09-17-2002).]
  3. gre406
    Oct 6, 2001
    611
    These might help a little more..Let me know..
    Geo
    http://userweb.nni.com/gre406/34-2.jpg
    http://userweb.nni.com/gre406/34-3.jpg
  4. Bob Reichel
    Bob Reichel Registered User
    NAWCC Star Fellow NAWCC Member
    Feb 13, 2001
    976
    Tried to print with no legible help. Would someone be so kind as to type the content so I can put a copy of the text in file.
  5. gre406
    Oct 6, 2001
    611
    Bob R...I will reduce the "monster" file to 50 percent and email to you direct...Let me know if you are able to print and read..
    Geo
  6. gre406
    Oct 6, 2001
    611
    Someone ask to see a photo of the clock..
    Geo
    http://userweb.nni.com/gre406/wb34.jpg
  7. Gordon Andersen
    Gordon Andersen Registered User
    Oct 4, 2000
    158
    I have been unable to bring up any of the pics or info on this double dial Waterbury.
    What am I doing wrong?
    Gordon Andersen
    Adams, Wisconsin
