Water Wheel won't turn on Cuckoo
Discussion in 'Clock Repair' started by sparkleplenty, Mar 16, 2017.
  1. sparkleplenty
    sparkleplenty Registered User
    Apr 15, 2014
    44
    California
    #1 sparkleplenty, Mar 16, 2017
    [​IMG]I did several repairs on a Cuckoo that has three weights, it has a couple guys sawing wood, and another guy chopping a log (which activates with the music box and the water wheel) which are powered by the third chain. My problem is that the plastic water wheel won't turn, the rubber wheel that the chain feeds through is probably worn and there is not enough friction against the chain passing through the groove to make the rod that holds the water wheel turn. I tried adding an additional thin flat rubber gasket to the center groove of the two rubber sides to build it up to make the wheel thicker through the middle groove but it still is not enough to turn the rubber wheel making the rod holding the plastic water wheel turn. There is a small rod in back of the rubber wheel that pushes the chain close to the center of the rubber wheel, is that rod able to be adjusted closer to the rubber wheel? I know this is a simple fix and once I can get enough friction on the chain, the water wheel will turn, it did briefly, but stopped. I made sure the water wheel was tight on the rod outside of the box. Thanks if you can help me? Good to be back fixing clocks!
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,867
    watchmaker
    Western NSW, Australia
    Without pictures I'm only going from memory. The third chain runs the music box and the water wheel runs off that?
  3. bangster
    bangster Super Moderator
    16,313
    20
    I don't have a lot of experience with these, but from what I recall, the chain that runs the sawyers and choppers has a loop that runs back toward the back of the clock, and across a sponge rubber wheel that drives the mill wheel.
    If this is yours, you need to increase the traction with the rubber wheel, so's the chain will turn it.
    Either replace the rubber wheel, or coat it with some thing that will increase the traction. One possibility would be tincture of benzoin.
  4. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    I have had good luck with these rubber part problems by putting on a thin layer of rubber cement. Before it fully dries I wipe it off then let the piece dry completely. Once dry, I lightly sand the surface with 800 grit. I suppose the solvent in the rubber cement does most of the job.
  5. shutterbug
    34,341
    30
    I always remove the chain and check the friction on the wheel itself. If it won't turn easily by itself, you'll never get it to turn with the music train. You might have to remove it and make sure everything is smooth and polished at the rotation points.
  6. sparkleplenty
    Apr 15, 2014
    44
    California
    Thanks, Bangster, I increased the traction in the grove of the rubber wheel by cutting a very thin line of two sided sticky rubber and wrapped it around the center of the wheel making sure it was joined at the ends. Then dusted the surface lightly with corn starch to make it less tacky and blotted off any excess. Like making a new rubber band to fit in groove of rubber wheel. It worked great, water wheel turns nice and strong! Thanks for your suggestion.
Similar Threads - Water Wheel won't Forum Date
How do you think he did this? Tide Clock that raises water. Clock Repair Mar 24, 2017
Oil or water quench? Clock Repair Oct 10, 2016
Cuckoo clocks that drive water wheels Clock Repair Feb 8, 2016
SCS Clock Cleaning Solution--Water vs. Petroleum Based Clock Repair Dec 4, 2015
Help Identifying Cuckoo Clock movement with water wheel Clock Repair Sep 28, 2015
