Watch Parts Wanted
Discussion in 'Watch Repair' started by raiser, Nov 12, 2012.
  1. raiser
    raiser New Member
    Nov 10, 2012
    Hello, I'm looking for minutes hand or both hands for Systeme Glashutte pocket watch. My watch should look like $(KGrHqVHJC8FBmEHKtUJBQe0MlgBJ!~~60_57.jpg , but now looks like DSCF1322 resized.jpg .
    Thanks,
    Raimundas
  2. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    3,406
    94
    Gothenburg
    raiser,
    Could you give us the length and hole size of each of the hands. I have a lot of these hands but need to know what size you need!
  3. wilsonpaule
    wilsonpaule Registered User
    Oct 23, 2011
    345
    Hudson, Quebec
    Okay, my understanding of the case for the Waltham 1888 was off a bit. Richie c explained it to me in a pm. Stem does not reside in movement, but I am still looking for a case for a Waltham 1888!
  4. richiec
    richiec Registered User
    Feb 24, 2007
    6,429
    343
    automotive warranty inspector
    Brick, Ocean, NJ
    Yes, these cases were specific to the 1888, due to the thickness of the 1888 movement, they do not fit a normal 16 size case. You will also find that some of the dials with the outer minute registers, will not fit in a normal case, the dial interferes with the bezel. Usually the only way you find a case is with a movement in it. I wish you luck.
  5. richiec
    Feb 24, 2007
    6,429
    343
    Brick, Ocean, NJ
    I am looking for an Illinois 18S, 17J, model 5, lever set lower center wheel jewel, held in with 3 screws, in a non-gold setting, I have checked the parts houses to no avail, anyone out there got one?
  6. hotserman
    hotserman Registered User
    Oct 27, 2012
    7
    Hi
    Wanted rolex calibre 190 mainspring 150 X .06 X 180
    regards judd
  7. sderek
    sderek Registered User
    Jan 8, 2009
    2,681
    Watch repair/ Watch sales
    USA
    Have you tried Bryan Eyring, Brian Cavanaugh, or Bob McKnight? They have a lot of good used material for American pocket watches. Their contact info is in the part sources sticky.
  8. sderek
    Jan 8, 2009
    2,681
    USA
    #8 sderek, Nov 29, 2012
    You should be able to order this from any supplier- just order it by size. I see Jules Borel has one that is very close. It's tongue end, and is 1.50 x .060 x 190.5- It should work just fine. And if Jules Borel stocks it, other suppliers will have it as well.
    I see Jules Borel also one listed by Rolex caliber- they have it as a 1.50 x .060 x 200. Again, if Jules Borel has it, others will as well. Just call them up and order by caliber number.
  9. sderek
    Jan 8, 2009
    2,681
    USA
    #9 sderek, Nov 29, 2012
    Cas-ker offers a service whereby, if you send them your case, they will fit a sleeve and stem for a reasonable fee.
  10. vanhooglesnort
    vanhooglesnort Registered User
    Oct 14, 2012
    I need a balance complete, or at least a hairspring for an Elgin 4/0 caliber 485.
  11. sderek
    Jan 8, 2009
    2,681
    USA
    Someone may come along with an offer for them... but, if you'd really like the parts, just contact either Bob McKnight, Bryan Eyring, or Brian Cavanaugh. They have large selections and reasonable prices. Their contact info is in the Part Sources sticky.
  12. Gasper
    Gasper Registered User
    Oct 14, 2012
    56
    Thank you sderek.
  13. vlado
    vlado New Member
    Dec 5, 2012
    I am looking for a glass for the pocket watch shown on the pictures PREDNA STRANA.jpg ZADNA STRANA.jpg
  14. sderek
    Jan 8, 2009
    2,681
    USA
    I'd be happy to sell you a crystal, but I need to know what diameter (in mm) that you need. These can be tricky, as it requires a tight friction fit and it is sometimes easier to just send the bezel, unless you want an assortment. Sometimes it is necessary to glue in a slightly smaller crystal with UV cement or clear epoxy.
    Dashto and Dave's Watch Parts, also supply crystals. Their contact information is in the Parts Sources sticky.
  15. 6789
    6789 Registered User
    Dec 3, 2012
    69
    hokgkong
    sorry i have none of them mainly Swiss watches i have noel
  16. sderek
    Jan 8, 2009
    2,681
    USA
    I responded with an offer to supply a crystal, but it appears the bezel itself (the ring that holds the crystal) is missing. Do you need both a bezel and crystal? If you need a bezel, consider sending the entire watch to Don Barret at City Bank Antiques, or if he can't supply the bezel, you could send it to Jerry Grajzl in Ohio- he can make a new bezel for just about any watch. Their contact info is available on my website here: http://www.watchrepairinfo.com/misc.htm
    I've used both Jerry and Don with excellent results.
  17. sderek
    Jan 8, 2009
    2,681
    USA
    Be sure to insure your package if you send it!
  18. Marty W
    Marty W Registered User
    Jan 10, 2012
    533
    Supporting Doctors
    LA (lower Alabama)
    Hello:
    I am in need of 2 pairs of 18-size keywind hands (hour/minute) for 2 Elgins that I am trying to resurrect.
    Please PM if anything is available.
    Thanks,
    MartyW
