Watch newbie looking for help
HistorySeeker
New Member
Jun 19, 2021
I cant find any information regarding this pocket watch. Not that i have much experience for looking either. But this is nice mystery to search i bought this from 50$ at auction. Its allways fun to search was it good or bad deal.
thanks for any possible help
JTD
Sep 27, 2005
8,862
785
Welcome to the board.
Your post will do better in the correct pocket watch forum. A moderator can move it for you - please don't start another thread as it becomes confusing.
JTD
viclip
Jul 20, 2018
820
589
93
Well, your "Empress" gold-filled case was made by a Canadian company out of Toronto, Ontario known as the American Watch Case Company.
Your movement seems to be Swiss-made however the photograph is a bit fuzzy so I'm unable to see details clearly.
It would be helpful if you could also post a photograph of the dial.
Rick Hufnagel
Just Rick!
Oct 25, 2018
2,452
3,703
37
Pittsburgh pa
Welcome to the forum!
Your watch movement is what is called a "Swiss Fake". These were made to look like nice domestic movements but are inexpensively made and often had misleading or completely untrue marks in them. In your case I highly doubt the watch has 21 functional jewels. See this nice article from the forums encyclopedia.
Vic explained your case, but here is an article on the company. There were two American watch case companies, yours applies to the Canadian maker.
As far as good or bad deal...does the watch run? Are the dial and hands in nice shape? I can't tell what condition the case is in from the pictures either, but if it's not worn down to the brass and the watch runs and looks good than I'd say your fine. If you like it, $50 is certainly an acceptable price for a complete watch with a gold filled case.
Have a good day!
Reactions: viclip
HistorySeeker
New Member
Jun 19, 2021
HistorySeeker
New Member
Jun 19, 2021
I hope those photos were little better.. at the back where is crown and on top of it text empress and below crown is A.W.C.Co and
Following numers in V shape 1609483.
Also at the rim there is series of numbers 09483.
viclip
Jul 20, 2018
820
589
93
From the photo of the back of the case, it seems to be in very good condition. Depending on its size I'd say that the case is probably worth $50 alone, assuming there are no issues with it.
You didn't mention the size of the watch/case, just wondering ...
The dial & hands look to be in good shape. Note additionally to what Rick said above, that below the seconds subdial the dial indicates "Swiss".
All in all you got yourself a nice Swiss watch which will make a fine daily carry (assuming that all is in order & that you have it cleaned/oiled/adjusted plus have any issues taken care of which may be found during servicing).
viclip
Jul 20, 2018
820
589
93
How does the watch run?
In looking at the photo of the balance wheel area, it seems that the rear part of the regulator indicator (the "pointer") is missing.
If so, I'd expect the watch to lose time.
gmorse
12,641
2,227
Hi HistorySeeker,
Yes, it appears to be, that's the part which should have the index pins in it to alter the effective length of the balance spring. The balance spring itself looks rather disorderly and in that state the watch may not run at all.
Reactions: MrRoundel
MrRoundel
Dec 28, 2010
1,420
276
So. Cal., USA
I agree that the hairspring situation makes it unlikely the watch is keeping good time, if running at all.
I'm wondering if the watch is hiding a different looking, gilt-finished, movement under the top plate? Jerry T. has posted about a watch he found that had an added plate that was screwed onto the "actual" functioning plate. The depth around the visible jewels makes it look that way.
gmorse
12,641
2,227
Hi MrRoundel,
I'm sure you're right, and I wouldn't be surprised if the actual jewel count doesn't tally with what's engraved on that false top plate, (which has no technical function). As we know, in genuine watches the visible jewels on the top plate should have matching mates in the pillar plate under the dial, but in these watches they often don't; just another aspect of the deception I'm afraid.
GaryWoodward
Jan 26, 2021
29
42
13
66
The challenge for each successive owner, is to just enjoy the watch for what it is, and not worry too much about all the things that it isn't. It has a charm all of its own.
Agree - Wise words that can be applied in much of life.
Reactions: Old rookie
167,206
1,457,081
87,368
luc1lle160
