Most visitors online was 1660 , on 12 Dec 2020
Hello Dave, I checked that code and it was 855, (see pic) I guess that means August of 1945? Or would it be Aug. of 1955? The clock was removed from an old Braniff Airways Terminal at Dallas Love Field years ago. It was found like this. with no casing around it. How do you think it was mounted? Thanks again, for your help!!Find the date code stamped on the Telechron B-2 rotor. Usually the lower/right number sequence.
Now use my date code deciphering guide (probably format #4 but it could be #3):
Telechron Rotor Date Codes
That will tell you the exact month and year the rotor was produced. That looks like the clock's original motor so it should be a close approximation of the clock's age.
P.S. that's a very interesting clock
Again I thank you Dave, you have been a ton of help on this. Sounds good on the mounting also. I guess Im lucky the clock works, and is in decent condition. I will check with telechron.net too. I appreciate it Dave have a good day!It's Year, Month, Decade. 855 = May, 1958
That looks like an unusual mechanical movement (maybe even non Telechron). My guess is the clock was panel mounted. Maybe in the airline's main dispatch office, control room or crew lounge. Maybe it was mounted along with some weather instruments as part of a custom display.
You might want to post at telechron.net. Maybe those guys have some other clues.
