Warranted Aluminium..... or is it?
Discussion in 'American Pocket Watches' started by Mark UK, Mar 20, 2017.
  1. Mark UK
    Mark UK Registered User
    Apr 13, 2015
    268
    Lincs, UK
    I have found a few old threads here discussing these cases but none of them came to any conclusions... maybe someone has something new to add?
    The case is solid, weighty, well built, hinges are still as tight as when new but.... it has no makers marks apart from the words 'Warranted Aluminium' around a crown. Ignore the movement, I quickly added a spare 1883 keywind to show that it is as good a fit as any English silver or coin silver cases I have seen. The case has no movement screw marks, none, nothing to suggest what it might have originally housed. Aluminium spelled the English way, but the US used this spelling for a while. A fleur-de-lis on the rear so could be French but this symbol is widely used around the world. A Waltham 1883 sits perfectly, but I have had a couple of Swiss keywinds with exact same profile and wind position. Any ideas?
    What is it made of? It says Aluminium but it carries a lot of weight. The color suggests brass. On the inner glass bezel, on the dial flange and around the movement fitting flange I can clearly see rose gold, so was it plated? Does Aluminium take gold plate? If it was entirely plated in rose gold which has now worn or been polished off then why is the engraving on the rear still fairly fresh, or at least I would have expected this to show a lot heavier wear. If brass then why does it say 'Aluminium'... is this an early forgery?
    Curious... I have only had it for a few hours and already I have fallen in love with it and have a beaut of an orphan 1883 ready for a new home :)
  2. Tom Huber
    Tom Huber Registered User
    Dec 9, 2000
    2,749
    It is more than likely aluminum. Noted the English spelling--Aluminium. In the 19th century, Aluminum was an expensive metal due to the processing. It only became common when new and cheaper processing methods became available.
    I have several aluminum cases, all from the 19th century. They are good, functional, solid cases.
  3. Tom McIntyre
    Tom McIntyre Technical Admin
    Staff Member NAWCC Member Sponsor
    Aug 24, 2000
    78,107
    402
    146
    retired SW dev
    Boston
    The very similar one I have is marked "Alumigold" and appears to be an aluminum copper alloy perhaps with a bit of iron in it.
  4. Firegriff
    Firegriff Registered User
    Feb 22, 2013
    566
    One of the stories I have herd about the early uses of aluminum is that they made some civil war medals out of it because it was worth more than gold at the time mostly because it takes large amounts of electricity to make and there were not many large electrical generating plants in the 1860's
  5. Mark UK
    Apr 13, 2015
    268
    Lincs, UK
    Thanks Tom, once again I think you have nailed it. I've just been reading up on the alloy 'Aluminium Bronze' and it appears that the alloy of aluminium and copper has a variety of properties depending on the other ingredients, such as iron, nickel or lead.... that explains the weight. An early alloy was used for jewellery because of it's close color to gold so I would bet that was where the watch case material originated.
    So the answer is 'yes' it is aluminium and the 'warranted' is somewhat credible with anywhere from 10% upwards of aluminium content, after all it was still an expensive material at the time.
  6. Tom McIntyre
    Aug 24, 2000
    78,107
    402
    146
    retired SW dev
    Boston
    Aluminum was made by something like distillation at the beginning, I think. I am almost certain it was not made with electricity until around 1900. If I were not too lazy to look it up, I think the process is described pretty thoroughly. Maybe Wikipedia would be a good place to look.
  7. novicetimekeeper
    Jul 26, 2015
    5,012
    Dorset
    Napoleon III was said to have had an aluminium dinner service because it was worth more than gold.
  8. 4thdimension
    4thdimension Registered User
    Oct 18, 2001
    2,060
    11
    In 1884 when the Washington monument was capped with it the
    price of aluminum was $1- an ounce.-Cort
  9. Firegriff
    Feb 22, 2013
    566
    from the Wik way over my pointy headi--The conversion of alumina to aluminium metal is achieved by the Hall–Héroult process. In this energy-intensive process, a solution of alumina in a molten (950 and 980 °C (1,740 and 1,800 °F)) mixture of cryolite (Na[SUB]3[/SUB]AlF[SUB]6[/SUB]) with calcium fluoride is electrolyzed to produce metallic aluminium:Al[SUP]3+[/SUP] + 3 e[SUP]−[/SUP] → Al
  10. Firegriff
    Feb 22, 2013
    566
  11. topspin
    topspin Registered User
    Dec 14, 2014
    1,158
    I remember touching on this at school during both chemistry and geography. The geography bit was that wherever you find an aluminium plant, you'll often find its own dedicated power station (typically hydro-electric) right next to it.
Similar Threads - Warranted Aluminium Forum Date
Keystone Pocket Watch, Hunter case marked "Warranted Fine Solid Gold" American Pocket Watches Apr 21, 2017
Warranted 18K ? American Pocket Watches Nov 2, 2013
Case markings Warranted Standard U.S. Assay American Pocket Watches Apr 14, 2012
Madison pocket watch Case--Stamped Madison Warranted 5 years--4743351 American Pocket Watches Mar 14, 2012
Aluminium Case American Pocket Watches May 9, 2008
