Warped Wooden Pendulum Rod
Discussion in 'Clock Repair' started by gleber, Sep 29, 2019.
  1. gleber
    gleber Registered User
    Jun 15, 2015
    1,664
    179
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    Can this be straightened? If so, how?
    Also, are the two rating nuts:
    1. Used to lock the nuts in place
    2. The lower nut is used as a fine regulation
    3. Just an extra one someone added
    Thanks,
    Tom
  2. Willie X
    Willie X Registered User
    12,479
    864
    I think the two nuts are used to lock the adjustment.
    I have seen several instances of a single nut that creeps downward over time and some companies took extra measures with different devices to keep this from happening.
    So, slightly jamming two nuts together is a simple way to solve an annoying problem.
    Clocks seem to work just fine with a warped stick. Replaceing it is the only cure AFAIK.
  3. bangster
    bangster Moderator
    19,515
    366
    There is a way, but it's not worth the trouble. What Willie said.
  4. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,166
    404
    Is this out of a Long Case?
    The only way I know of to remove warps and dents in unfinished wood (without cutting, planing or otherwise mechanically re-shaping it) is to expose it to water/moisture and then apply corrective force until the wood dries. If the wood is finished so that moisture can't enter easily, I don't think it can be attempted without stripping the finish.
    Of course you could always replace it and reuse the hardware as Willie has already suggested
    I tend to agree with the advice of Willie and bangster... unless it really bugs you, leave it as is.
  5. bruce linde
    bruce linde Technical Admin
    5,961
    596
    oakland, ca.
    you could clamp it straight between two 36" levels (for example) and leave it in the bathroom where you shower for a week or so and see if that helps... but it's not that bad.
    otoh, i have found those second regulating nuts to be nothing but a PITA... lose it, use one.
  6. gleber
    Jun 15, 2015
    1,664
    179
    Thanks for the recommendations guys. I plan to leave it because it is original and otherwise in fine condition. But my OCD cringes a little when the tick and tock are not centered even though it is in beat. o_O
    Tom
  7. shutterbug
    41,807
    926
    You could make one easy enough. Your local lumber supply will have trim pieces that are just about the right size and shape.
  8. kologha
    kologha Registered User
    Dec 11, 2011
    382
    13
    Retired Production Engineer, Nissan SA Motor Con
    Eastern Cape SA
    To straighten warped wood it has to be wet and then bent slightly beyond the straight (to allow for the natural spring in the wood) and then held in that position and allowed to dry. I have successfully straigntened the butt on a Martini-Henry using damp cloths and a vise. Took a few days but it was successful!
    leeinv66 likes this.
  9. gleber
    Jun 15, 2015
    1,664
    179
    Thanks for the additional suggestions. It's nice to hear multiple ideas.
    Tom
  10. bangster
    bangster Moderator
    19,515
    366
    To expand on previous remedies:
    Put it under stress (somehow) so the bow is corrected.
    Put a damp cloth on it.
    Go over the cloth with a clothes iron (steam or otherwise) to provide heat and moisture.
    Allow to cool
    If it still needs more straightening, do it again.
    Wash, rinse, repeat.
  11. kologha
    Dec 11, 2011
    382
    13
    Eastern Cape SA
    Bangster's method can also be used to raise dents in wood (as long as the fibres aren't broken). I have raised dents in gun stocks that way and it works well.
  12. shutterbug
    41,807
    926
    If the steam will penetrate the paint, that will work.
  13. gleber
    Jun 15, 2015
    1,664
    179
    This is one of those good tips that you forget about when you need it because you don't use it frequently enough. I need more RAM and better search tools. ;)
    Tom
