Wanted 30-tooth escape wheel two-weight regulator
SAMcCloud
Jan 4, 2020
Hello all.
(x-posted in Clock Parts Wanted)
I am looking for a 30-tooth escape wheel for a 2 weight regulator. The movement is unmarked as to maker and date, but is consistent with other "Vienna" styled movements. Customer has 8 individual regulators and this is the 3rd in for restoration. Not sure how the prior repairs got this far.
Also pictured is a "cousin" and the case for this movement.
The escape wheel is off of its arbor and out of round. The pivots on the arbor are good. I do not have a deadbeat gear cutter that will fit this small. Thought I would check before I ground a tool.
If you have the wheel and arbor, thank you! I can stake a new wheel if that is what we can locate.
Dimensions:
Outside diameter tooth-to-tooth is 25mm
inside diameter is 3 mm
pinion has 8 leaves
arbor length pivot to pivot is 27mm.
Thank you
Scott McCloud
47,840
2,292
You could have one made for you, if you can't find an original.
SAMcCloud
Jan 4, 2020
Do you have a lead on someone? The man I used has passed away.
s
Latest posts
169,823
1,482,214
49,179
noynac
2,965
