Waltham Wm. Ellery
Hoopty
Oct 22, 2001
112
I have a model 57 #120720 that finally broke its staff (had been bent for some time). I am looking for a replacement staff and am curious if there was a part number given by waltham for the staff (since it is so old) Bruce
This was also posted on the 185 site.
Hoopty
Oct 22, 2001
112
Julian Smith
Sep 1, 2000
823
Visit site
Here are Some of the numbers.There may be others.
Series A--sprung over #277 Hub .41 thick
Series A--sprung under #278 Hub 1.03
Series A--sprung under #279 Hub 2.14
Series A--sprung over #281 Hub 1.25
You might figure out which one you need from this.
J Smith
Hoopty
Oct 22, 2001
112
Julian,
Thanks for the information.. It is undersprung which narrows the field by 50%... I have never had to measure a hub before.. where is it measured at.. Is there a special device needed?
Don Dahlberg
Aug 31, 2000
3,425
20
You just need a micrometer to make the measurements. The hub would be the maximum width of the ledge or table that the balance sits upon.
The dimensions are in mm. If your micrometer is in inches, there are 25.4 mm/inch, so multiply your inches by 25.4.
The following numbers are:
Total Length
Lower Height (end of lower pivot to bottom of balance)
Balance shoulder seat. (hole in balance)
Roller table seat. (Width of staff where roller held on)
Pivot diameter.
Waltham 18 size model 1857 Sprung under-Short waist #278
5.63 4.46 1.60 0.59 0.16 mm
Waltham 18 size model 1857 Sprung under-Long waist #279
5.71 4.42 1.62 0.60 0.18 mm
From American Pocket and Wrist Watch Balance Staff Interchangeability List, by G. E. Townsend and R. Ehrhardt.
Don
167,149
1,456,526
87,338
bobby212
