Waltham Vanguard Mainspring
Discussion in 'Watch Repair' started by beepilot, May 19, 2017.
  1. beepilot
    beepilot Registered User
    Nov 22, 2016
    25
    I have a recently acquired a 1901 Waltham 23j Vanguard 18S 1892 model pocket watch which is very stiff to wind and occasionally stops shortly after being fully wound. It has recently been cleaned and oiled and now keeps excellent time within a few seconds per day. It almost certainly doesn't have the original mainspring having been serviced/repaired several times in the past. I am beginning to wonder if it has been fitted with the wrong mainspring possibly one that is too strong for the watch. I know that the correct spring for the watch is No. 2222 which is available in various strengths/thicknesses. Can someone please tell me the correct strength/thickness mainspring for this 23 jewel version of the Vanguard and any advice on whether or not the wrong strength spring could be the cause of the above problems. Has anyone who owns this watch or has experience of one tell me if a stiff wind is normal or not. Thanks.
    Roger
  2. rrwatch
    rrwatch Registered User
    Sep 4, 2000
    1,291
    Watchmaker
    Pooler, GA USA
    Before you replace any parts, try lubricating the crown wheel. Sometimes doing this will make the watch much easier to wind.
  3. richiec
    richiec Registered User
    Feb 24, 2007
    5,467
    automotive warranty inspector
    Brick, Ocean, NJ
    Next question, who serviced it, how far down did they take the watch, did they lubricate all parts.
  4. PWfanatik
    PWfanatik Registered User
    Jul 7, 2015
    936
    Building trades Project Manager
    Right, as Richiec implies did they go under the dial and under the barrel and in other places...
    How does it feel when you set the watch? Does it feel smooth as you run the hands all the way around the dial?
    Under the dial the wheels can greatly effect the running and time keeping of a watch.
  5. beepilot
    Nov 22, 2016
    25
    Thanks for the replies. The watch has been fully and properly serviced and lubricated by a professional who has worked on other Waltham Vanguards so this is not an issue about a servicing. My understanding is that Vanguards are fitted with a range of different mainspring strengths (probably 0.15 - 0.20) according to the jewel count, the higher jewel counts needing the lower strength springs. Hence I'm thinking it possible that at some point in the past a too strong a mainspring has been fitted thus causing potential problems e.g. stiff winding. Therefore I'm asking anyone with actual experience of a Waltham 23j Vanguard what is the correct strength spring for this watch and do other owners experince problems similar to the ones I have mentioned.
  6. Mark UK
    Mark UK Registered User
    Apr 13, 2015
    268
    Lincs, UK
    From my experience the strength of the spring has minimal effect on the winding smoothness. Is yours a 2222? I would check the width/length for possible binding and also check for worn barrel arbor/bushes especially if it has a tendency to stop occasionally after a full wind.
    2222 mainspring: 3.25-3.30 mm wide, .15-.20 mm thick, 25 inches long (Waltham material book)
  7. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    1,944
    Doctor
    Linköping, Sweden
    I'd say that the fact that the Watch stops after being fully wound is a bigger issue than the Watch being hard to wind. The Winding issues could have to do with anything from the Crown down to the mainspring. The Watch stopping however puts you in an entirely different part of the movement. If could be overbanking, hands could be binding or there could be any number of gears bindning in the going train. The two could be linked, of course, but I would recommend taking it back to the repair person to sort it out. You have at least one serious issue in the Watch.
    Best regards
    Karl
  8. richiec
    Feb 24, 2007
    5,467
    Brick, Ocean, NJ
    karlmansson, I don't think beepilot said that the is watch stopping, he states it keeps very good time.
  9. karlmansson
    Apr 20, 2013
    1,944
    Doctor
    Linköping, Sweden
    Maybe I misunderstood, this was before the recent service?
  10. MrRoundel
    MrRoundel Registered User
    Dec 28, 2010
    819
    Real Estate Broker on hiatus
    So. Cal., USA
    I have an Omega that I had to use a significantly stronger spring in. It too is hard to wind. Smooth, but surely more tension than it was designed for. I mean I've really got to grab that crown and twist with force. Sometimes you've got to do it. However, I'm guessing that the lowest strength 2222 spring is available, so you should be able to get the proper one for yours.
    What does your watchmaker say about what seems like extraordinary resistance in the winding mechanism? I'm pretty sure that, like most 18s American models, the barrel-bridge is removed without having to disassemble the train, so your watchmaker could remove the barrel fairly easily to check the MS strength. There would probably be some nominal cost, but it would answer your question. There's also the possibility that they will have a "aha" moment when they try to wind the watch and attribute it to something else. Good luck.
Similar Threads - Waltham Vanguard Mainspring Forum Date
Waltham Vanguard 16s Watch Repair Jun 16, 2017
18s Waltham Vanguard Watch Repair Apr 23, 2017
Mechanical WW Waltham 1908 Vanguard - cannot wind suddenly Watch Repair Jan 2, 2016
American PW Waltham 16S Vanguard Mainspring Part # needed Watch Repair Dec 27, 2010
American PW installing new mainspring in jewelled parrel waltham vanguard Watch Repair Jan 7, 2008
