American Waltham Pendulum Info Needed
Discussion in 'General Clock Discussions' started by pmatson, Mar 12, 2020.
Need missing pendulum info.
  1. Pictures of similar pendulum
    1 vote(s)
    100.0%
  2. Lead on parts
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. pmatson
    pmatson Registered User
    May 11, 2016
    20
    I have a customer who has a 9 tube Waltham grandfather clock that is missing the pendulum rod and leader with beat adjuster and suspension spring. This clock has a tag that states it was a gift to a gentlemen in the Elks on April 2 of 1924, assuming it was new it was probably built in 1922 or 1923. The serial number on the bottom of the back plate is 11157.
    It has a 3 tube mercury pendulum but the mercury was spilled out in transit, the picture shows it inverted.
    Any pictures of a similar clock with the pendulum, leader and suspension spring would be appreciated. I can probably fabricate most of what is missing but I need a starting point. Any lead on old Waltham parts or drawings will also be desired.
    Best Regards
    Clock face.jpg Front 36.jpg Notch and Pin.jpg Pendulum weight.jpg Scale post at bottom.jpg Works Back 19.jpg Works Back Left 42.jpg
  2. Andy Dervan
    Andy Dervan Registered User
    Gibbs Literary Award NAWCC Star Fellow NAWCC Member
    Oct 23, 2002
    2,338
    See my conversation to you.
    Andy Dervan
  3. upstateny
    upstateny Registered User
    Oct 2, 2015
    553
    35
    You could use the rod from a standard Waltham. I have one here that I will take pictures of and post them.
  4. upstateny
    Oct 2, 2015
    553
    35
    The spring is very similar to a Herschede, the one pictured here is an original Waltham. It is the type used by your clock.
  5. pmatson
    May 11, 2016
    20
    Thank you upstateny -- do you have a picture of the leader & beat adjustment?
  6. upstateny
    Oct 2, 2015
    553
    35
    There is no leader as such, the pendulum rod has a slot milled in it that slips over the post on the crutch. The beat adjuster is the threaded affair on the end of the suspension spring in the first picture. In a pinch you could use the Herschede part after a little tweaking, I have done this but you need to shorten the Herschede spring or perhaps make a new spring that fits the Waltham slot in the first picture. The picture does not show the pin that holds the spring in place.
  7. upstateny
    Oct 2, 2015
    553
    35
    #7 upstateny, Mar 14, 2020
    This should make it all clear to you. With the slot in the rod over the crutch pin, the nuts on either side of the shaft on the spring is shifted left or right to achieve the correct beat. Old Walthams are built like a tank!
  8. pmatson
    May 11, 2016
    20
    Thank you, this clears things up. One more question or assumption -- so it looks like I will need to thread/tap the suspension spring so when you turn the nuts it will move left or right?
  9. upstateny
    Oct 2, 2015
    553
    35
    Yes, not easy to see but the top end of the spring has a rather thick brass block which is tapped to match the threads on the top rod. Does your customer just want the clock to run or are they trying to put it back to factory?
  10. upstateny
    Oct 2, 2015
    553
    35
    Given that the dial says Waltham Clock Company I would guess the clock was built prior to 1922. Waltham changed their name to the waltham clock and watch company in 1922/3.
  11. pmatson
    May 11, 2016
    20
    We are going to just get it to run. It looks like I will need to make a round rod to match the pendulum and a wood or flat leader. best regards.
  12. upstateny
    Oct 2, 2015
    553
    35
    OK, good luck with it! Since all of your viles are intact, you might want to consider having steel turned to fit the vials and eliminate using real mercury. It is dangerous but the main problem is the cost of a flask of mercury 2-3K$ for 1 flask around 29 pounds.
  13. pmatson
    May 11, 2016
    20
    Thank you for the info, I will come up with turned steel of lead shot (I am from Idaho) for filler. I will make the pendulum flat and one peace with a suspension assembly at the top and a slot for the crutch pin. One of the pictures shows a threaded post, I assume this is to lock the pendulum in place. A measurement from the top notch to the base of the pendulum would be a great starting point.
  14. upstateny
    Oct 2, 2015
    553
    35
    OK, I will make that measurement for you and post it. Well I am originally from Nebraska, so hello neighbor.
  15. upstateny
    Oct 2, 2015
    553
    35
    You may be better off using the standard lead/brass standard bob instead of the three vial. More available and less construction details to mess with. I will get you the measurements you asked for.
    This picture is the rating assembly for the standard brass/lead bob, the brass nut is what is used to raise and lower the bob to get accurate timekeeping.
  16. pmatson
    May 11, 2016
    20
    OK, upstate -- looking forward to the measurement/picture if you have a mercury set up.
  17. upstateny
    Oct 2, 2015
    553
    35
    Here are the pictures of a standard pendulum.
  18. pmatson
    May 11, 2016
    20
    Thank you so much for your time, these pictures are all I need to get going.
  19. upstateny
    Oct 2, 2015
    553
    35
    You are welcome! The length of the pendulum is the same regardless of the bob style standard or three vial. The only difference is the top hook and suspension spring but that is goverened by the back cock style on the movement.
    Regards
  20. upstateny
    Oct 2, 2015
    553
    35
    I will get my microeter out tomorrow and get you WxD measurements on the pendulum rod as well as the size of the slot for the foot of the crutch.
  21. pmatson
    May 11, 2016
    20
    Hi, any luck with measuring the WXD and slot? Hope all is well and you and family are virus free.
  22. upstateny
    Oct 2, 2015
    553
    35
    Yes! Here you go!
    All measurements are in decimal inches.
    Pendulum rod
    0.62 wide
    0.16 thick
    Slot
    0.7 long
    0.152 wide
    Placememt of slot centered on pendulum rod.
    Top of slot 4.5 inches down from top of pendulum
    Bottom of slot 5.25 inches down from top of pendulum
    Suspension feather
    1.45 inches long
    0.40 inches wide
    0.0045 inches thick
    Have a look on eBay for Waltham 9 tube pendulums....900-1300$
  23. upstateny
    Oct 2, 2015
    553
    35
    Here is hoe the suspension spring is attached to the pendulum rod.
  24. pmatson
    May 11, 2016
    20
    Thank you all, I am good to go.
  25. pmatson
    May 11, 2016
    20
    Per the picture of the mercury pendulum shown above (it is up-side-down) There is a threaded portions with a thum-bwheel -- what is it for:???::???:? I am just guessing but is it to fine tune seconds:???:
  26. pmatson
    May 11, 2016
    20
    Here is another picture of the nut on a threaded shaft. The ID of the shaft is about 5/8 in diameter and there are two set screws. Any thoughts ?? I am perdy sure there should be a round shaft that connects to the pendulum. I think the rough rating is accomplished by loosening the set screws and moving the heavy mercury pendulum bob up or down.
