American PW Waltham model 1883 parts
IowaWatchGuy
Dec 24, 2004
26
Hello all,
Would a complete balance from a 7 jewel model 1883 Waltham fit and be appropriate for a 17 jewel model 1883 Waltham? What about the fourth wheel with seconds pinion?? I am restoring a 17 jewel model and am trying to find out which movements I can rob parts from or basically where to get these parts.
Thanks!
IowaWatchGuy
Dec 24, 2004
26
Hello all,
Thanks!
Don Dahlberg
Aug 31, 2000
3,425
For the model 1883 I have to balances listed.
1376 - Balance, Expansion Small
1378 - Balance, Expansion Large
For the 4th wheel I have
1297 - Fourth wheel, Gilt Small Hole 80 Teeth
1297A - " " " large hole " "
1298 Fourth Wheel, Gilt, 80 teeth and pinions, 10 leaves for K.W. or Hunting S. W.
1301 Fourth Wheel, Gilt, 80 teeth and pinion, 10 leaves, for O.F. S.W. only.
So the answer is maybe. There seems to be two balances and two fourth wheels. If they are both OF the fourth wheel should work.
One place to look for parts is Uncle Larry at http://www.execulink.com/~lfoord/index/waltham.htm
Don
IowaWatchGuy
Dec 24, 2004
26
Ok,
I have the movement in front of me now. I have found the fourth wheel ok, but here is my delima. The balance wheel is here, but the roller table and hairspring are gone. (This is a private label movement otherwise I would not bother restoring it!) My question is, how hard will it be to get this watch to run correctly with a NOS hairspring?? Or, would it be better to look for a used complete balance? I would prefer to use the one originally on it, but I am not made of money. :)
Any help is appreciated!!
Smudgy
May 20, 2003
2,874
23
You should be able to bring a new hairspring on your original balance to time by adding and removing weight. The timing washers are even rated for how much they'll change the rate. Removing weight and maintaining poise may take a little tinkering, but not too much.
That's assuming a studded spring. If it's not studded you'd need to vibrate it to time.
Don Dahlberg
Aug 31, 2000
3,425
Vibrating a fresh hairspring is a skill that most people who took watchmaking courses learned to do, but forgot. It is also rather time consuming so it is hard to find someone to do it. I assume it is not cheap. Jim Micheals still does it and I am sure there are others out there. I do only for my own watches.
You can get a studded hairspring off a parts watch or a studded NOS harisping and it should be close enough that adjusting the mass of the balance as suggest by Smudgy should work. Dashto has a parts movement at http://www.dashto.org/newlists/partialmovements.htm
Don
Topic related ad experiment
160,943
1,396,193
82,924
waynebernelli
1,099
2,788
