Hi All,
Back from a summer of home projects and back to watches.
A friend sent me his newly purchased Model 1883 to look at.
Symptoms: When my friend received it - it was running. Some time after (not specified - maybe a couple of days) it stopped and balance wheel wouldn't oscillate for more than a few seconds. Eventually he sent it back to the seller who did 'something'. He got it back, running, smelling of some 'solvent' and again after a short number of days it stopped again. When I got it the balance wheel would only oscillate for a few seconds, despite the mainspring being almost fully wound.
I took it apart, cleaned and oiled it. (While 'overall' it looked clean, under a microscope the gear pivots (axles?) seemed dirty and also having maybe some grooves. - After cleaning it definitely looked much better - see some photos. I know it's not perfect, but we're not looking for 'railroad' quality. Note that the balance wheel roller was really caked and I cleaned it a couple of times and got it somewhat better, but not fully clean. I oiled and put it all back together. (Interesting - when you put it together take care that the pallet arbor end fits into a slot in the plate indentation - if you don't see that you'll try to put on the plate and it will never close.) It's been running for a couple of days now. Mainspring seems fine.
Question 1: Is there something that a seller might have used to 'temporarily' make the watch run (both times), which dissipates after some days? I'm wondering whether the watch will stop again, after the work I've done, or if the previous experience was no indicator of what I might expect after my work?
Question 2: I've never worked on a watch with a pallet arbor (instead of a pallet fork). I noticed that the balance wheel is rotating about 180-190 degrees or so. With a pallet fork I'd shoot for 270 or so. Should I expect differently for this 122 year old Model 1883 with a pallet arbor? It's keeping time to within a minute a day or so.
