American PW Waltham Model 1873-6
Discussion in 'Watch Repair' started by richiec, Jun 28, 2008.
  1. richiec
    richiec Registered User
    Feb 24, 2007
    5,537
    automotive warranty inspector
    Brick, Ocean, NJ
    I need the proper part numbers for the setting lever and setting lever spring on a Waltham Model 1873-6 pendant set and stem wind, SN 4230061 Seaside Grade 7 jewel. The watch runs well but is missing the setting parts. Another thing that puzzles me is the barrel/train bridge had to be taken off to get the watch out of the case as the stem screws into the winding bar tip which is under the bridge. Is it possible that this is not the proper stem and it was originally a two piece stem?enclosed are some pictures.
  2. Tom McIntyre
    Tom McIntyre Technical Admin
    Staff Member NAWCC Member Sponsor
    Aug 24, 2000
    78,099
    402
    146
    retired SW dev
    Boston
    This was posted a long time ago, but I think it is interesting nevertheless. If the stem shown in the watch screws apart into two pieces and there is a flat on one side of the piece with the gear, then it is probably the original stem. To remove the watch from the case, a pin is placed in the hole in the middle of the 5 pointed star and it prevents the lower piece from turning which allows the upper piece of the stem to be screwed or unscrewed.
    This stem arrangement was also used on other watches up to 14 size.
  3. richiec
    Feb 24, 2007
    5,537
    Brick, Ocean, NJ
    Gee, only 9 years later do I get the answer I needed. I have to look and see if I still have this one, doubt it though. thanks Tom, just in case I get another one.
  4. PWfanatik
    PWfanatik Registered User
    Jul 7, 2015
    936
    Building trades Project Manager
    Richie can we see a photo of the edge of the movement?
    While I have no Waltham in this serial number range, I feel a lot like the case and the stem are from a dollar watch, (those, I am quite recently familiar with)
    Good luck in figuring this out.
    Dave.
  5. richiec
    Feb 24, 2007
    5,537
    Brick, Ocean, NJ
    PWfanatik, like I say, this thread started 9 years ago, don't think I have the watch anymore.
  6. PWfanatik
    Jul 7, 2015
    936
  7. Jerry Treiman
    Jerry Treiman Registered User
    NAWCC Member Donor
    Aug 25, 2000
    5,130
    26
    Geologist - California Geological Survey
    Los Angeles, CA
    If you look closely at Richie's original photo you can see the slot in the end of the stem. When the movement is assembled and in the case, one can insert a pin through the starred hole in the plate that will enter that slot and lock the piece from turning so that the stem/crown can be unscrewed from that piece, leaving it in the assembled movement. I can see the resemblance to a dollar watch assembly, but the similarity is only superficial.
  8. richiec
    Feb 24, 2007
    5,537
    Brick, Ocean, NJ
    Now, if I only knew this 9 years ago, I might have kept the watch. Learn something new every decade.
Similar Threads - Waltham Model Forum Date
Waltham 14S model 1876 staff Watch Repair Nov 2, 2017
Waltham Model 1883 Grade AmWCo Watch Repair Jul 17, 2017
Waltham Model 845 Repair Watch Repair Jun 29, 2017
Waltham Model 845 Watch Repair Jun 1, 2017
Waltham Model 1884 winding mechanism Watch Repair Jun 1, 2017
