Waltham M-1872 movement
Discussion in 'American Pocket Watches' started by sandlapper, May 21, 2018.
  1. sandlapper
    sandlapper Registered User
    May 20, 2018
    108
    Gentlemen, What type of case did these models (16s M-1872) come in originally, and will the case interchange with a M-1888 16s movement? If not what size case can be adapted to work? Thanks Sandlapper
  2. topspin
    topspin Registered User
    Dec 14, 2014
    1,386
    166
    It can be done to get an 1872 to fit into a case from which you have ejected an 1888, but only with the aid of some, er, "engineering". So, if you're good at metalwork then you stand a chance. Otherwise, you're stuck with an orphan, which you will probably have to just enjoy for what it is.
  3. sandlapper
    May 20, 2018
    108
    Thanks for the advice.
  4. ben_hutcherson
    ben_hutcherson Registered User
    Jul 15, 2009
    3,138
    316
    Chemist
    Kentucky
    For a lot of reasons, shoe horning a '72 into an '88 case is a bad idea.
    If you keep your eyes open, 72 cases do occasionally become available. With that said, unless it's a fairly high grade movement, it's usually not an economical swap.
  5. Bila
    Bila Registered User
    Jan 22, 2010
    1,053
    258
    Forget about trying that change, Model 1872 movement are thicker and will not fit as they protrude out through the back and you will not be able to close the curvette.
