• Upcoming updates
Waltham Chronometer Clock
Haybayler
Jun 18, 2021
I recently bought this and Waltham miniature clock. It has a serial # 18772371. The mechanism is an 8 day watch. Search comes back to made date of1912 ,size 16, model 1908. I have searched through many photos of this series. I haven't seen any in this type of clock. the dial arrangement is different, also. The large size, 1 7/8 inches, seem similar to the Chronograph, used on ships and automobiles. The old clock needs a lot of restorative work (wish me luck). I had it running (mostly) the first day.
My first question is what is the small dial with the red dot? Possibly an alarm?
Jmeechie
Dec 8, 2010
649
256
Hi,
What you have is a miniature banjo produced by Waltham Watch Co and the movement is a 8 day 37 size movement I suspect and not a 16 size movement. The small dial with the red indicator in the hole is a wind indicator function. On the 7th to 8th day of running the red dot will appear in the hole or window indicating it is time to rewind.
These movements were used in travel, miniature shelf/mantle, wall, car, ships/boats and military vehicle/aircraft clocks. They vary in jewel range and if you post a picture of the movement it’ll be easier to determine.
Cheers,
James
Haybayler
Jun 18, 2021
Hi,
Cheers,
James
Thank you for your response. I appreciate the information that you provided. I am uploading a picture of the movement. It is in very good shape. as I mentioned, it is about 1.75 inches wide.
CORRECTION: The movement is 2.75"
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,404
3,064
86
Boston
awco.org
I did a presentation on the myriad uses of the Waltham 37 size. There was also an earlier article that was similar and focussed more on the Boudoir painted dial clocks.
rmarkowitz1_cee4a1
Nov 26, 2009
6,679
1,864
View attachment 673505 View attachment 673506 View attachment 673507 View attachment 673509
Interesting.
Waltham miniature banjos made in approximately the 1st 1/4 of the 20th century or so were fine products.
The quality of the cases is just wonderful. The glasses were hand painted. Here are 2 examples that I currently own:
I suspect that your Waltham miniature banjo was home made using an available Waltham movement. It looks like someone used a photographic post card for the lower "tablet". Quite crude but now without its charms. Beyond the movement, I doubt very much that it is a Waltham product.
RM
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,404
3,064
86
Boston
awco.org
Chris Carey's teardown of the 37S movement is also included as a serties of stills. The full video may be available on the Chapter 8 web site.
Foster Campos made a small number of the miniature banjos using Waltham 37 size movement that Pat Caruso modified for front winding. I do not own one, but they looked to me to be better than the Waltham pieces made the same way.
Haybayler
Jun 18, 2021
Thanks, I will research that. You guys on this forum are Awesome.
Michael Post
Mar 20, 2018
13
Southern California
Tom, I have a Waltham 37 in a marine chronometer version. Do you know how the movement is accessed? I suspect that this brass case is threaded about half way down and will unscrew but looking for some confirmation before diving in. all this new to me.
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,404
3,064
86
Boston
awco.org
The counterweight has been removed in the picture of the bottom above. Unless the joint is badly corroded, which it does not appear to be, you should be able to grasp it with one hand and unscrew it from the upper piece. This is much easier if you back off the screws that hold it in the gimbals and remove it from the box. You can also just remove the gimbal assembly by releasing the catch on the inside of the case near the lock.
Here is the link to the pdf file in your post. From War to Boudoir
Michael Post
Mar 20, 2018
13
Southern California
Worked like a charm, many thx. The back spun right off. I now know that I have #22132499. I see how the counter weight should be properly attached and will be able to put this back correctly. Thank goodness for the Forum.
180,015
1,570,294
54,342
FrankNichols
911
3,090
