Waltham - Canadian Railway Time Service - Great find!
Discussion in 'American Pocket Watches' started by wilsonpaule, Nov 9, 2018.
  1. wilsonpaule
    wilsonpaule Registered User
    Oct 23, 2011
    344
    Hudson, Quebec
    Hi All, I have not posted here in a long time, but figured this was worth sharing and I have a couple of questions.
    I was at an estate auction today and in among a box of pocket watches I found a beauty! Been a while since I got this lucky!
    Waltham, serial # 7711674, model 1883, Grade Crescent Street.
    What makes this one more interesting is that it is Marked "Canadian Railway Time Service". I have done some research, but cannot determine how many of these were made with this marking. Does anyone know?
    I have a number of model 1883s, but this is the first one I have encountered personally marked like this.
    It has the correct Canadian 24 hr dial (which will clean up beautifully) and appears to be in its original case (Manufactured by BANNER). I realize that Waltham manufactured the watches and exported the movements to Canada to be cased.
    The case is very worn.....not sure if I should try and shine it up or not....what is everyone's opinion on that?
  2. musicguy
    musicguy Moderator
    NAWCC Member Sponsor
    Jan 12, 2017
    2,740
    895
    New York State
  3. wilsonpaule
    Oct 23, 2011
    344
    Hudson, Quebec
    Music Guy, Yup, I took a closer look at the case and you are correct, it does have a second set of screw marks on it. No big deal to me. Would I prefer the original case? Sure I would, but I am not going to worry about it. I am just pleased o have been able to find this watch and add it to my collection.
  4. wilsonpaule
    Oct 23, 2011
    344
    Hudson, Quebec
  5. Kent
    Kent Registered User
    Gibbs Literary Award NAWCC Fellow NAWCC Member
    Aug 26, 2000
    18,030
    1,084
    I wouldn't be so sure of the total quantity of 2102. You might find the "Waltham's Canadian Railway Movements" Encyclopedia article helpful.
  6. wilsonpaule
    Oct 23, 2011
    344
    Hudson, Quebec
    Hi Kent
    Thanks for pointing me to that great information in that encyclopedia article you posted. The problem is, I may be more confused than before. It is kind of hard to tell how many of the 1883, Crescent Street, marked Canadian Railway Time Service were actually made. Do you think there are more or less than the 2102 that Brian MacDOnald mentioned in his research?
  7. Kevin W.
    Kevin W. Registered User
    20,846
    93
    Wow Wilson paule, thats a really nice movement. I would not be concerned about extra screw arks either, awesome find.
  8. Kent
    Aug 26, 2000
    18,030
    1,084
    You're correct; "It is kind of hard to tell how many of the 1883, Crescent Street, marked Canadian Railway Time Service were actually made."
    There are a number of issues that cloud the total numbers of any of the Waltham Canadian railway watches that were built. That these total numbers are indeterminate isn't clearly pointed out in the "Waltham's Canadian Railway Movements" Encyclopedia article which will have to be updated to stress that fact (*sigh* one more thing to do).
    Insofar as only a relatively few of the model 1883 movements is listed as CPR grade and none as CRTS in Waltham records, I don't know how Brian MacDonald arrived at his estimates. In fact, even for runs listed as CPR and CRTS in "The Gray Book", examples have been reported as grades other than what was listed. And, for examples shown in the Encyclopedia article as a grade other than CPR or CRTS within a serial number range, there are reported examples of movements bearing the grade name interspersed between the examples of CPR or CRTS marked movements.
    By the way, Brian didn't claim that there were 2102 model 1883, CRTS movements made from Crescent Street runs. He wrote that there were 2102 model 1883, CRTS movements from all grades' runs. So, I'd say that there were not very many model 1883, CRTS movements made from Crescent Street runs.
  9. testguy
    testguy Registered User
    Dec 21, 2005
    420
    #9 testguy, Nov 14, 2018
    Some years ago, I used the reported examples from the Encyclopedia and calculated how many CPR & CRTS watches were listed from known runs. Using this number I calculated how many watches of each type were manufactured. These results are gusstimates at best, but provide some idea of how many of each model were produced.
    From my presentation:
    It is impossible to determine how many CPR and CRTS watches were produced by Waltham. Some years ago, I worked from the NAWCC's reported examples of CPR and CRTS watches. Based on complete runs, I determined how many were reported. I then did the math which resulted in the following estimates.
    18 Size CPR Model 1883 5128
    18 Size CPR Model 1892 17j 2307
    18 Size CRTS Model 1883 2102
    18 Size CRTS Model 1892 1435
    From the Gray Book, we know the following production numbers from complete runs:
    18 Size CPR Model 1892 21j O.F. 500
    18 Size CPR Model 1892 21j Hunter 100
    16 Size CPR 1908 1250
    16 Size CRTS 1908 550
    The Gray Book has errors. For instance, my CRTS 1892 is listed as one of a complete run of 500 CPR's. The only way to establish accurate production numbers, is to get the watches reported in the NAWCC data base so researchers can piece together complete runs.
  10. wilsonpaule
    Oct 23, 2011
    344
    Hudson, Quebec
    Thanks for the information Testguy. I am guessing you were the person that wrote the original article I referenced above! I guess at the end of the day, exact #s are going to be approximations at best, but it is still one of the lowest produced watch I own (Except for my Agassiz).
