Waltham 37s 15j boxed chronometer
Michael Post
Mar 20, 2018
13
Southern California
Does anyone have a reference on how to access the movement on one of these 8 day small clocks? The dial bezel unscrews but not the back, which has a free hanging brass counter weight. All this is new to me so feel free to treat me like a dummy!
Jim Haney
Sep 21, 2002
7,658
3,062
73
Decatur, TN.
The brass counter weight should be threaded and unscrews.
That will open the tub and you should see 2 Movement screws like a watch has...
Pictures are always helpful
Michael Post
Mar 20, 2018
13
Southern California
You were correct, the counterbalance did screw off however the pin that holds it onto the mechanism is threaded on both ends and thus detached from both the counter weight and the mechanism and is now rattling around inside the case. As you can see, this left me with no new paths to get inside the case. :???:
Picture of dial is with bezel and crystal off.
Jim Haney
Sep 21, 2002
7,658
3,062
73
Decatur, TN.
When you unscrewed the bottom Look into the back of the movement and you should see the Case screws. There is also a Stem release screw up by the Stem so it will come out. Furnish a picture of the Turn upside down so we can see the Watch Movement, Your terminology is Lacking in what you are trying to describe (PIN) ?
Michael Post
Mar 20, 2018
13
Southern California
The middle photo is the bottom of the case with the counterweight unscrewed.
Michael Post
Mar 20, 2018
13
Southern California
What did you do to remove the weight?
I unscrewed the counter weight as suggested in an earlier post. Looking closer, it appears as if the case may split/unscrew in half if I removed the clack from the gimble. Trying to proceed with caution as a neophyte. Found instructions on disassembling the movement but no data at all on this case.
179
Sep 16, 2008
917
461
Did you remove a fastener in the center of the weight?
Michael Post
Mar 20, 2018
13
Southern California
Found the secret. Worked another forum string on Waltham automobile clocks and those folks knew all about it as it is an adaptation of an auto clock for the war effort.
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,593
3,121
86
Boston
awco.org
Actually, your difficulty was fortuitous. I had never given a lot of thought to the "shape" of the mass in the counter weight. The array of holes serves to match the weight on both sides when lying face up in the gimbals. That is clearly why the weight is held by a screw so the mass can be put back in balance.
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
181,325
1,582,139
54,771
rjjeffries
3,126
Top
