• The NAWCC Museum and Library & Research Center will reopen starting Wednesday, January 6, 2021 as per Governor Wolf's reopening mandate.
Waltham 18k solid gold case?
Dr. Jon
Dec 14, 2001
6,189
669
New Hampshire
The case almost certainly a Waltham case and near 18K gold. The mark is not a hallmark but a brand grade. Most US gold cases were at least 1/2K under that the mark stated.
If you mean by original made by Waltham watch case company. IF you mean original to the watch, you need ot check the movement side for case screw marks. If there are extras not where the case screws are now the movement is not original to the case.
Reactions: pdaneu
pdaneu
Apr 2, 2005
262
67
Sao Paulo - SP
www.carnivoras.com.br
As Dr Jon said, the case is 18k but the bow is a worn gold filled replacement.
Hi John,
Here in Brazil is very common watches in solid gold with the bow gold filled.
IWC, Vacheron, etc..
American watches with 18k solid gold is very hard to find in Brazil, this is the first that I found and I was think that the bow was original due the lots Europeans with the gold filled bows.
Paulo
Reactions: John Cote
richiec
Feb 24, 2007
6,952
660
67
Brick, Ocean, NJ
It is a shame someone was very shoddy in the way they pried the case open, scratching it so badly. I am drawn to these 14S watches and have at least a half a dozen but only 3 in cases.
