Waltham 1888 re-case & question.
DTSPatrick
Jul 9, 2020
106
240
44
Saint Petersburg, Florida
What am I doing wrong? I can’t seem to remove an 1888 movement from its case. I have two watches that I’m swapping cases — I loosened the screw (photo above) and was able to remove the stem easily for this movement; however, loosening the screw on the second movement isn’t releasing the stem. The stem does become more loose and I’m able to move it up and down a little but it won’t disengage. Any ideas what I can do?
Also, can I swap out an oxidized crown wheel on an 1888 without disassembling the whole movement and letting down the mainspring? Are the crown wheels the same on OF and HC 1888 movements?
Thanks for your help.
Kenny S.
Apr 12, 2020
250
396
56
Not far from South Park CO
If you've loosened the screw sufficiently, the stem will come out. It has to. Make sure that you have backed it all the way up. The screw attaches to a plate that engages a groove in the stem that allows you to switch from winding and time setting. If this plate is stuck or corroded in place, it may be what's binding. As far as the crown wheel, you can swap it without dis-assembly, but definitely let down the mainspring first. I confirmed by trying it on one of my un-cased, unwound '88's. I think the crown wheels are the same, but not 100% sure.
--Kenny
Reactions: DTSPatrick
Skutt50
Mar 14, 2008
3,898
257
Gothenburg
Sometimes it helps to push on the screw to press the lever/plate a tiny bit further down.
Another, more complicated method is to let down the mainspring and to remove the barrel bridge with the movement in the case. That usually exposes the mechnism and any problem with a stuck stem.
DTSPatrick
Jul 9, 2020
106
240
44
Thanks for the input Kenny and Skutt50. I’ll give it a couple more goes before I try to disassemble.
Reactions: Kenny S.
167,179
1,456,764
87,348
Criseldis
