I still don't understand the problem here... In most watches I've assembled (ok, ok - not that many, but still) these were the pilar plate's bearings depressed slightly in the plate, prepared to help the watchmaker fit the pivots inside. Rodico, paper clips - one can leave residue, the other is unnecessary pressure on the forh and it's pivot, while all that can be done really very simply, by placin all parts on the top plate and gently covering them with the pilar plate.
One has to simply hold the pilar plate in proper position (not turning it when it's down on the pivots
), aim for the center arbor that goes in and then try to fit in the seconds pinion. Easy - really. Later tha pilar plates rests on the three remaining pivots and all you have to do is to fit the (at least in Elgin and Illinois) 3rd pinion, fork pivot and escape pivot in their holes. And since the bearings are silghtly depressed, the pivots are right next to them.
In a high quality movements, no additional pressure is needed the pilars jump in their holes without resistance, so all you have to do is to slightly help the piviot in it's hole. When it's done you just turn the movement around, which - again - is quite simple, check all pivots again, if they have not jumped out while turning the movement, and secure it with screw(s).
Believe me - this is simple. No further, potentially dangerous manouvers needed. Of course, one can have his own way, but it's a bit like forcing an open door...
