Visible vs. Audible Center of Clocks
Discussion in 'General Clock Discussions' started by Tom McIntyre, Sep 11, 2002.
  1. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    82,537
    1,570
    176
    retired SW dev
    Boston
    The tick-tock should be even. Your clocks are out of beat. On some clocks there are beat adjustment mechanisms that let you set the relationship between the pallets in the escapement and the pendulum position with respect to the case. On other clocks it is necessary to bend the crutch wire to put the clock in beat. Usually you just get it close enough that it does not look absurd and then use the sound to put it properly in beat.
    For wall clocks you can usually move it a bit left or right on the hanger. For mantle and shelf clocks some card stock under one side or the other usually works.
    If you are a real purist you twiddle with it until it is perfectly in beat with the clock case level and the pendulum in the center of the scale (if there is one).
    Tom McIntyre
    NAWCC 2nd VP Candidate
    Tommy the JOAT's Web
  2. Tom Chaudoir
    Tom Chaudoir Guest
    Before you bend anything, check to see if the clock has automatic beat correction. Move the pendulum a bit more to one side than it would noramlly go, and give it a swing that's a bit harder than normal.
    If the crutch is made of wire, you don't have auto beat correction.
    Tom Chaudoir
    Milwaukee, WI
    America
    53204
