No, the spelter parts don't need cleaning. Just dust them. You could use Brasso on the bezel.can I use brasso to clean the specter parts?
JTD
Yes, just dust, or use a slightly damp cloth at the most. Both clocks are nice and of similar quality, so one isn’t “worse” than the other. I’m the figure on the second one is spelter as well. If it is bronze, however, that obviously makes it better than spelter. Personally, I find the second clock more appealing, but that’s just my opinion.Some final questions: can I use brasso to clean the specter parts? Would this clock be better or worse than my other French clock? View attachment 598827
You mean you put the entire statue in?best way to really clean these is to completely disassemble them, everything is just bolted on, use a mild soap and water, then be sure everything is totally dry before re-assembly. I use an ultrasonic myself, but not everyone has one, or one large enough.
You don't disassemble the marble as Steven said. I just use car polish to clean marble (not any with abrasives). With porous rock, just use mild soap and water (on a towel). Don't soak any of it as it's all only held together with plaster that will easily dissolve.How do I disassemble the marble?
