Vigor Motor
Discussion in 'Horological Tools' started by Yastrimsk, Feb 16, 2020.
  1. Yastrimsk
    Yastrimsk Registered User
    Jan 1, 2014
    21
    Hello. I have an old Vigor lathe motor. It’s 115 volts ac/dc. My question is, how many amps and what hp is it ? I’m interested in purchasing a variac speed controller and concerned about getting one that’s safe for the amps that I have. I’m looking for plug and play, no complicated altercations. Also, is there any basic maintenance that can be done to these motors, do the need oil or grease ? Thanks in advance. 337B9F83-CCB4-41C1-8146-E4CB9F66975E.jpeg
  2. topspy
    topspy Registered User
    Nov 17, 2013
    628
    30
    Video engineer
    Oregon
    Most of these are 1/10 Hp. I'm not sure how many amps, but it will be quite small. I have rebuilt several of these (various types.) First loosen the pulley setscrew and remove the pulley. Remove the brush cover screws on the side, and remove the brushes and springs. Be careful as the brush holders are bakelite and quite brittle. If they break you can superglue them back together. Remove the screws that hold the two motor halves together and gently pull the motor apart. Remove the armature. Some motors have bearings, others do not. If it has bearings test them to see that they spin with no 'crunchiness.' Replace them if needed,most are common sizes and are labeled on the side, and you can order them from many suppliers. Blow out any debris and lightly sand the commutator (where the brushes rub) to remove varnish. If the power cord is in poor condition you can replace it, but this is usually the most difficult part. Reassemble and test. If there are no bearings make sure to apply oil to the bushings (Non bearing motors usually have oil cups or oilers on them.)
  3. Yastrimsk
    Jan 1, 2014
    21
    Thanks for all the info.
  4. Dr. Jon
    Dr. Jon Moderator
    Dec 14, 2001
    5,655
    424
    Aerospace Engineer
    New Hampshire
    I use a Variac with several ac motors and it works well. Variac is a trademark of General Radio and their stuff was made well. Non brand Variacs look likes may not be as good and condition matters.
  5. measuretwice
    measuretwice Registered User
    Jul 28, 2019
    36
    15
    Toronto
    1 HP = 750 watts., 1/10th = 75 watts. Putting aside efficiency etc, A=W/V = 120/75 = .625. Hardly anything.
    A Variac is a variable transformer and kind of overkill for this imo....given it's a universal motor you could get a foot speed control for less money. Speaking for myself, I think a foot control is a requirement for a watchmakers lathe (if that's the application)....I'd find it awkward without one
