Vienna with warped door.
Shadowraith
Apr 7, 2017
51
70
New Jersey
Any ideas on getting the door straight :???: Thanks for any feedback. John
13,473
1,314
Shad,
Not easy to repair a warped door. If it has two hooks just use the one that will pull in the warp. A latched warped door should not be noticable. Willie X
Reactions: Shadowraith
leeinv66
Mar 31, 2005
10,283
291
Launceston Tasmania
How bad is the warp? If it is more than just a slight warp, repairing it will see you needing to redo the finish.
JimmyOz
Feb 21, 2008
778
164
65
Gold Coast Qld
It's part of its history, timber never stops moving, I would just leave it.
An Example;
I was an antique furniture repairer back in Edinburgh and the Queens residence Holyrood Palace got central heating in about 1972 and a Tudor oak table that had been there for 100's of years split open due to the dry air.
bruce linde
ADMIN / MODERATOR
8,325
1,161
oakland, ca.
clockhappy.com
in extreme clock restoration, tom temple says it's possible to straighten plates of wood movements by re-introducing moisture to the concave side of the plate using a damp towel, and then clamping plate and towel straight to a piece of wood.... but wood movement plates don't have glass in them, and probably aren't sealed with a finish like this door.
probably best left alone... but i empathize with another one of those 'small things about my clock that bug me' moments.
Shadowraith
Apr 7, 2017
51
70
New Jersey
I know. There's no easy way. I'm a a bit surprised the glass hasn't cracked. Still I plan on trying. I know why it happened. When I purchased the clock years ago. Even than closing the door was an issue. I was too focused on getting it up and running to notice the doors center hinge was missing. Hence dry air and time has worsened the issue. My bad. Was looking for possible solutions that I might not know about. Thanks for your response.
wow
Jun 24, 2008
4,945
484
75
Pineville, La. (central La.)
It looks like it is warped pretty bad with a bow in the middle. If it is so bad you need to straighten it, you can try removing the glass and laying it on concrete with the center warp upwards and cardboard protecting each corner. Then place a brick or some other weight in the center of the bow and use a steamer to add moisture and heat up and down each bowed piece. Leave the weight on while it dries and cools. You may have to do this several times to get the bow out. Then you will probably need to refinish. I have also used this method to straighten bowed pendulum rods on long case clocks and Vienna’s.
164,686
1,432,667
85,738
cspeed8
2,863
