• Upcoming updates
Vienna Regulator acquisition
Phil G4SPZ
Oct 18, 2018
664
135
70
Bewdley, Worcestershire, UK
I was very lucky to have been given this rather imposing twin-weight Vienna in a walnut case. The case is in pieces and needs cosmetic attention, and the pendulum rod has snapped at the crutch pin slot, as the clock had apparently been moved with the pendulum attached.
The movement has maintaining power, a dead beat escapement with Vulliamy pallets, and rack striking on a gong. The pivots are very fine. Apart from being quite dirty, the movement looks like it will not require major work. The porcelain dial is virtually pristine. The only mark is a serial number, which reads 24698.
Can anyone suggest a possible maker and date? My first thought was Lenzkirch but this is the first proper weight-driven regulator I’ve dealt with and I know little about them. My wife is likely to throw her hands up in horror when she sees this clock, which measures 52” or over 130cm tall overall, but I have always liked this style of clock and will try to persuade her to find a space for it!
Any advice or info would be much appreciated.
Phil
4FB23E4F-D5DA-40B9-863F-434BC036C373.jpeg 9A1998F9-3313-4E43-A11D-86A3015BFD1D.jpeg 6A53AE19-7FC4-4284-AD91-2802BF8982C7.jpeg CF4D2D59-E623-4B5A-B3FA-A0213DE93886.jpeg 57379900-D90F-4750-91F7-A8C0C8940B43.jpeg
new2clocks
Apr 25, 2005
4,752
1,003
Pennsylvania
Phil,
First, that is a beautiful clock.
If your movement were a Lenzkirch, the serial number would fit into the time period (circa 1861) when Lenzkirch had no trademarks registered and used no logos.
However, I do not believe the movement is a Lenzkirch, but others may know better. LenzkirchFan is our resident Lenzkirch expert and he should be along to confirm or correct.
Regards.
Reactions: Phil G4SPZ
Tatyana
Jan 2, 2016
729
299
Saint Petersburg
Phil
View attachment 754591 View attachment 754592 View attachment 754593 View attachment 754594 View attachment 754595
This is the Freiburg company Concordia circa 1885.
For comparison:
Regards
Tatyana
Phil G4SPZ
Oct 18, 2018
664
135
70
Enamel it is, Mike!
Tatyana, thank you very much for identifying what is certainly a Concordia clock. There is a Concordia thread running on this MB and I will post pictures there. Judging from the serial number it dates from the second half of the nineteenth century.
This Forum is amazing! Thanks to all,
Phil
179,980
1,569,981
54,331
KaiEr
911
3,090
