Video camera f
Discussion in '400-Day & Atmos' started by TQ60, Nov 23, 2019.
  1. TQ60
    TQ60 Registered User
    Sep 15, 2016
    204
    Madera CA
    We found a book digitizer at a thrift store that has a gooseneck mount for the camera. It will do macro or close in viewing which we found is great for watching the escape wheel interact with the pallets on our Atmos.
    We have a picky little guy that would run with 450 so more degrees of rotation then after a couple days we find it stopped.
    This is post cleaning unit.
    Watching the pallets interact with escape wheel is interesting.
    Every once in awhile the tooth seems to hang up on the pallet and it does not clear, the pendulum pushes it back against the tooth, then it goes.
    On some other teeth of the escape wheel cause the rotation to of the wheel to go slightly backwards as the tooth slides off the side of the pallet.
    Looks like maybe the escape wheel teeth need close look under microscope.
    Here are some photos of what we can see with the camera in use.
    The largest image was using zoom on the phone to enlarge what was on the video screen.
    The camera was $5.00 at a thrift store, good investment!
    20191123_170404.jpg 20191123_170457.jpg 20191123_165753.jpg 20191123_165800.jpg
  2. Kevin W.
    Kevin W. Registered User
    22,631
    397
    Very interesting camera. Never seen one like that. You cant beat the price.It takes great pictures.
  3. TQ60
    Sep 15, 2016
    204
    Madera CA
    We have been collecting assorted cameras and microscopes for aiding tired eyes.
    This one has the goose neck so it can be placed in any position.
    We have an Epson that works well but it Jas a folding arm so desk work okay but sideways forgetaboutit.
    This one also has different resolution and capture so lots of fun things.
    Also picked up a Nikon stereo scope that works much better than others.
    We found a film of sorts on the pallet jewels that the simple brushing did not clean off.
    The escape wheel also had microscopic stuff on the teeth that we could not see with other means.
    Simple cleaning of the pallets and the escape wheel improved it greatly.
    The camera was great in that it will zoom the image to where the pallets barely fit the screen.
    In this view one can see the escape wheel tooth slide on the side of the pallet.
    It slides just a tiny amount but the sides may be missed as we think the faces see all the action and the side just stops the wheel.
    Carefully scraping the sides with a tiny sharp puck under microscope reveals a film of dried mystery stuff that added just a bit of friction.
    Yesterday we gave the clock the above attention and started it with less than 360 degrees rotation.
    Today it is over 480, before it was maybe 420 but not consistent.
    Will let it run a few days before we put the face and hands back on.
  4. James McDermaid
    James McDermaid Registered User
    Apr 29, 2011
    132
    Most video cameras run at a certain frame rate depending on the standard the camera is made for. Digital or analog, its not a continious flow.
    Like movies on film run at 24 frame per second. Thinking to actually see what is going on you would have to go at a super high frame rate.
    Just a thought.
    Jim
  5. TQ60
    Sep 15, 2016
    204
    Madera CA
    This is an Atmos...
    No need for speed...
    Camera has zoom that makes the single pallet view fill entire screen.
    Built in capture great for comparison shots.
  6. TQ60
    Sep 15, 2016
    204
    Madera CA
    So this morning it was stopped again.
    We had the camera in place so we gave the pendulum a gentle push with a single stringed artist brush and noticed the right pallet would not clear.
    It has power transfer to roller but at the very end of the stroke where the roller is cleared and just before it hits the front plate blanking pin it stops.
    When the pendulum spins back around it slides backwards slowing down the unit.
    It is rotating well past the exit point but the fork stops just before banking.
    Sometimes it would be okay after a few tries or it would stop.
    We captured the image and we assumed the angle on the pallet was good.
    It had a groove that we stoned off and the angles looked same.
    This clock has always been "funny".
    So we grab another clock that is a good runner and look at the action and we notice our angle is way off.
    We forgot to capture the example, but the good one when escape tooth is in the middle of the pallet is more open on left side while the other is more open on the right.
    When they are at exit point it looks like it is hooked.
    We stoned it just enough to tilt the face similar to the good one but not near the extreme and it seems to be working better.
    The teeth slide off smooth.
    Photos are where the tooth is sticking.
    A rough drawing of the angles and a post repair photo.
    The last photo looks fuzzy, at 1600% zoom of something the size of a fly's behind through a spaghetti sized hole it is not too bad.
    It needs to run a week before we claim done...
  7. TQ60
    Sep 15, 2016
    204
    Madera CA
    Well it ran longer before it stopped.
    But the camera helped again.
    Before the tooth would stop on the pallet.
    Now the pallet is clear and the escape wheel was just standing there clear not touching anything.
    Could easily see this.
    No power at the escape wheel.
    So carefully rocking the gears no change until we rocked the main spring.
    All gears were pushing but no change until we rocked the spring and it took off.
    We had cleaned and oiled the spring and it had what seemed like good pressure.
    When it was running it was 510 degrees rotation.
    Opened it up and looked close and there were some different color bands where it seemed like it may have been rubbing different.
    "Sticksion" a made up word maybe but it seems the spring has great power but given the almost zero movement it provides full power but does not slip as it should so power output decreases just slightly.
    Before the angle of the pallet was enough to cause the almost zero power to stop the escape wheel on the pallet.
    Changing the angle an polish reduced the friction such the tooth would clear but not continue.
    So we polished the spring both sides with comet and removed the odd color bands.
    Much solvent bath to insure no residue and reassemble.
    Started at 300 degrees and it was up to 480 later in the day.
    So on probation again...
    Camera did not come with the remote so we found one on eBay, camera with remote for $30.00 shipped.
    Best recent tool buy.
  8. shutterbug
    44,050
    1,322
    I imagine it's the wheel, not the spring. Look at the teeth, pinion and bushing condition. Mark it where it stops and see if it consistently stops in the same place.
    To save time, do the same thing with the second wheel.
  9. TQ60
    Sep 15, 2016
    204
    Madera CA
    Examined under microscope and all good.
    In a week of time the main spring wheel barely moves so surface tension may be issue.
    It has been running solid after the comet polish.
    The different color cross banding was caused by something, not sure what but the indicate friction or rubbing maybe.
    We suspect the surface of the spring may have had some texture or other imperfection, maybe oxidation as it does have varying color.
    That possible imperfection could have allowed just enough friction to make the wheel stick under the very slow rotation.
    Rocking the wheel "breaks" the surface tension and restores the power.
    Before last polish it would run at 510 degrees rotation and gradually drop to maybe 400 for a few days then stop.
    Now making over 550 degrees.
