Hello all,
I recently acquired a large collection of antique Tambour clocks, and one of the clocks they were selling was this Gilbert. after seeing the unique face design on the top of the case, I could not pass it up. It is fairly rough though, someone went along and used rub and buff pretty much all over the case, the trim, and the former marbleized sections on the case. Also, the left side feet on the clock are totaled. The back one is missing altogether, and the front one is mangled beyond repair. Unfortunately, these are unique as well, as I have not seen this design on any other black mantle clock feet. So it will be hard to find replacements. The whole clock is truly impressive and I hope to restore it to a usable and attractive condition. I just need help dating the clock, because unlike most Gilbert movements, the date is not stamped on the movement plate. However, I do have an original label on the bottom of the case which is in amazing condition considering the rest of the clocks issues. It is called the Triumph model, and I just wanted some info as to if someone knows when this model was first introduced in the Gilbert clock company. Also, how do you safely remove rub and buff from the black finish on a clock without damaging the original black finish. Thank you all, and I am open to all tips and advice as usual even if it does not regard dating the clock.
Thanks,
- Gage
Thanks,
- Gage
