Greetings All,
I saw an interesting clock yesterday while making a "house call" for a GF clock.
The clock case looks to be dark mahogany. It is a five tubular bell movement with thick plates and seems to be very well made. As usual, it took several minutes and close examination to determine how it would actually come out of the case. Remove the weights and pendulum, hands, dial surround (4 screws), remove the back fabric panel w/frame, remove tubes, remove 4 screws from the seat board. Remove two metal braces from the front of the movement that are fastened to the side of the case. Everything comes out the back. This little exercise took a total of 35 minutes.
There is a plate on the inside of the door marked "Vernon Hall Clock Co." Made by Cincinnati Time Recorder Co.
The only markings that I see on the movement are at "6 O'clock" on the front plate and possibly the rear, S444.
I did search the MB and came up with a couple of postings, one by Tom McIntyre from 2003
"I have an example marked "Vernon Hall Clock Co." Cincinnati Time Recorder. It came with a tag that said "came from Gov Watson's House in Boston 1914. This is a bit suspect since there was no Governor Watson. There was a Governor Walsh who served from 1914 to 1916. He was also the Senator from Massachusetts from 1918 to 1947.
If the tag has any validity, they would have been in business in 1914. The clock itself looks more like a mid 20's vintage to me. It is a 5 tube chiming clock.
Tom McIntyre
Another post from Harold Bain referenced LY's Longcase Clocks and Standing Regulators. The Model 101 clock case is very similar to the one I saw yesterday. (Of course, it's a master clock, self-winding movement etc......)
I don't have pictures of the case and dial but will take some when I take the clock back.
The chime weight is probably the same weight as the one on my nine tube Herschede (28-30 pounds).
The clock is very dirty and isn't chiming. The time cable needs to be replaced. Also a new suspension spring. There may be other things as I take a closer look.
Nice clock and I hope the repair goes as it should
Any other comments or information will be appreciated.
Best,
Richard T.
Tom McIntyre
Best,
Richard T.
