• Upcoming updates
verge problem
Carl Spencer
Apr 7, 2015
When my verge wheel tooth contacts the enter pallet, does the tooth need to be flat against the pallet? I don't think this verge it original to the movement because it don't look like an original one on another movement which I have. The tooth only enters on the very top edge of the verge, then the verge slides down the tooth to exit. But it runs for a week, but looks like this is putting more ware on the tooth and the top edge of the pallet. Don't see how the transfer of power could be all that good with no more contact. Still learning. Carl in NC.
R. Croswell
12,267
2,124
www.greenfieldclockshop.com
Is this the same Terry type clock that had the strike problem? If so I assume that you mean escape wheel tooth. It should not contact flat against the pallet. Would help to see a picture of what we are talking about. The pallet strip or verge is usually fairly thick on these but could have the wrong angles if it has been replaced or messed with. Just in case you may be unaware, these are usually hardened and will snap if you try to bend them.
Carl Spencer
Apr 7, 2015
Speaking of pictures. What type camera is best for taking close up pictures to help everyone see what I'm talking about. Have had this problem from the get go but don't have a camera but a lot of questions and I could help my elementary if I had a one. This my not be the right place for this reply but it landed where it did. If you need to move, I'll find it. If you tell me where it is! Like Patton Manning tells Brad Pasley, I think we're almost there. Good night and I'll look for you next time. Thanks, Carl in NC.
l
Carl Spencer
Apr 7, 2015
PS. Yes this is the same clock that HAS the strike problem. Have it apart now and see all the problems you mentioned. Need to shorten the the strike lever a few more thou, and I believe I'll be there. Thanks again. Carl in NC.
harold bain
40,853
192
74
Few things in clock repair need to be shortened, as few things on clocks ever grow longer with age.
Carl Spencer
Apr 7, 2015
When the strike lever all most falls out and only sticks part way through the strike arbor ,no crimp , something has to be done. That was the escape wheel. My nomenclature is not up to par yet.
bruce linde
10,691
2,399
oakland, ca.
clockhappy.com
l
do u have a cell phone? iphones take good pictures....
R. Croswell
12,267
2,124
You will get the best close up pictures with a camera that has a macro setting. I like Sony cameras but most "smart phones" today should be adequate, although the picture quality varies.
178,995
1,570,045
54,043
nrizzo
909
3,088
Swiss Fake by Kent
