UW325750 Questions
Discussion in 'Clock Repair' started by MuensterMann, Mar 17, 2018.
  1. MuensterMann
    MuensterMann Registered User
    Mar 23, 2008
    1,258
    14
    I have an Urgos UW325750 movement. I don't see this number in the replacement lists. However, I do see a UW32575 movement listed. Is in the same (zero being dropped)?
    It has this type of pendulum leader (shown below). What spring connects this leader to the post?
  2. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Life Member NAWCC Member
    Jul 4, 2009
    2,314
    94
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    Many misread the D at the end as a 0. The replacement is UW32342. We have it in stock. Kindly contact us a butterworth@butterworthclocks.com. Regarding the suspension spring for your original, it is a C plastic type.
    NEWOSA65 likes this.
  3. R&A
    R&A Registered User
    Oct 21, 2008
    4,177
    105
    It's an auto-beat spring
  4. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    156
    deceased
    How can a suspension spring be auto-beat??
  5. R&A
    R&A Registered User
    Oct 21, 2008
    4,177
    105
    Do you know what this is
  6. harold bain
    40,850
    156
    deceased
    It is a suspension spring for Urgos movements. What does that have to do with auto beat?
  7. R&A
    R&A Registered User
    Oct 21, 2008
    4,177
    105
    What spring connects this leader to the post. I believe it's this one . What do you think. There are 2 different size springs.
  8. harold bain
    40,850
    156
    deceased
    You have to know which size it needs. If you don't, buy one of each. Still don't know what this has to do with auto beat, though:whistle:
  9. Willie X
    Willie X Registered User
    12,774
    983
    #9 Willie X, Mar 18, 2018
    This movement uses the smaller one. To argue Harold's point, about 20 (?) years ago Urgos went to a high bridge design on the UW32. It uses a 'normal' suspension spring and a different leader. They also changed the tiny tooth escape wheel too but that could have been at a somewhat different time.
    All UW32s that were made, past the era of the funny looking moulded suspension spring, were autobeat. That often posed a problem because many were in narrow Grandmother style cases. Willie X
  10. MuensterMann
    Mar 23, 2008
    1,258
    14
    Thanks Willie for stating that I would need the smaller one (the shorter in length one)! Not sure how/where else I could find such information!
    One seller has the spring listed as "self adjusting".
    Hard to see, but I imagine that the black plastic at the bottom has a hanger for the leader to hang on. Yes?
  11. Willie X
    12,774
    983
    Yes, the leader locks onto the spring to minimise or eliminate any lateral wiggle. This makes for a better action on the autobeat feature.
  12. R&A
    R&A Registered User
    Oct 21, 2008
    4,177
    105
    Yes but the other model takes a different leader doesn't it :???: But the leader in question, takes the suspension spring I posted.
  13. Willie X
    12,774
    983
    Yes and yes ...
    :) Willie X
