Vint
- Oct 14, 2020
- 352
- 19
- 18
- 73
- Country
- Region
I am beginning work on a very old David Dutton ogee clock that I found stuffed in a antique room while in New Hampshire. The movement is in relatively good condition but the case is not. As I examine the case I see the top door glass panel has window glazing opposed to using slender wooden strips. Has anyone ever seen this practice on clocks before?
my second question is what I should use in the form of a protective coating over what’s left of the inside label bearing Mr. dutton’s name, warranty etc? I want to preserve the remaining paper label. Any suggestions are indeed welcome.
I’ve attached a few pics. Thank you.
