Use of aluminum for clock plates
Discussion in 'Clock Construction' started by doc_fields, Feb 19, 2019.
  1. doc_fields
    doc_fields Registered User
    Sep 29, 2004
    1,280
    23
    Clockmaker/Watchmaker
    Greentop, MO
    What obstacles would there be in using aluminum plate for clock plates? All pivots would be in ball bearings and/or jewels or brass bushing inserts. Just the aluminum used for the plates only, nothing else. Thoughts?..............gary
  2. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    633
    49
    Tulsa, OK
    I think it would be fine provided the aluminum is not a bearing surface as you indicated (use ball bearings, bushings or jewels.) I have been tempted to do the same thing myself with brass being so expensive. Let us know how it works out for you.
    doc_fields likes this.
  3. Harry Hopkins
    Harry Hopkins Registered User
    Nov 16, 2011
    544
    Retired Instrument Technician
    Mason, IL
    I will dig around in some past issues when I have a bit of time but I seem to remember a series of articles in the 'Home Shop Machinist' magazine within the last couple of years that was exactly as you inquire about... Constructing a clock movement with aluminum plates... Maybe someone else will remember... If I can find the correct issues in my library I will post again because if you are interested I think back issues are available.
  4. doc_fields
    Sep 29, 2004
    1,280
    23
    Greentop, MO
    Thank you Mr. Hopkins! Looking forward to it!..........................gary
  5. David S
    David S Registered User
    Dec 18, 2011
    7,174
    237
    Brockville, On Canada
    I love machining aluminum with my smaller metal working equipment. So from that perspective I think it would be a good idea. Even if it had to be a bit thicker for stiffness, it could then be a candidate for polymeric bushings like IGUS. The plates could even be anodized prior to inserting bushings to minimize oxidation over time and give them a nice finish.
    David
  6. doc_fields
    Sep 29, 2004
    1,280
    23
    Greentop, MO
    Thanks Allan!.................................gary
  7. Harry Hopkins
    Nov 16, 2011
    544
    Mason, IL
    Gary, I found the article on constructing a clock with aluminum plates. It is titled 'Making a Pendulum Clock' and It is a 4 part series in the 'Home Shop Machinist' Magazine. Part 1 is in the Sept/Oct 2016 issue and the rest of the series follows each issue for a total of 4 parts. I seem to be missing the Jan/Feb 2017 issue which would be part 3 but I loan my magazines to a buddy and maybe he still has that one. If you wish you can private message me with your address and I would be happy to loan them to you. If you rather you might be able to find back issues online. For the complete series you will need: Sept/Oct 2016, Nov/Dec 2016, Jan/Feb 2017 and March/April 2017. I will check with my buddy tomorrow to see if he has my missing issue.
  8. Phil Burman
    Phil Burman Registered User
    Mar 8, 2014
    173
    17
    Suffolk England
    Aluminium plates work just fine. I used them, together with aluminum pillars, in my prototype strasser regulator as per the attached photo.
    Dave T and doc_fields like this.
  9. doc_fields
    Sep 29, 2004
    1,280
    23
    Greentop, MO
    Harry, thank you very much for your efforts in finding those articles, and your offer to loan them to me. But, I wouldn't be comfortable borrowing them, as something could always happen to them while in transit to or from me, or while in my home (think grandkids). I really appreciate the thought though. I've decided to go ahead and try it here soon after the prototype is done, then if it's a go, I'll use aluminum plates on the final clock.
    I'm very aware of the effects of temperature on aluminum, and will compensate for any error that will affect timekeeping. Thanks so much for your response!.........................gary
  10. doc_fields
    Sep 29, 2004
    1,280
    23
    Greentop, MO
    Thanks Phil! Would be nice to see more pics of your movement!.............................gary
  11. Phil Burman
    Mar 8, 2014
    173
    17
    Suffolk England
    Have a look in this thread.
    Phil
  12. Phil Burman
    Mar 8, 2014
    173
    17
    Suffolk England
  13. Robert Doris
    Robert Doris AzBob
    Nov 7, 2010
    Prescott, Arizona
    As Phils nicely crafted movement in the photo suggests, aluminum plates with brass wheels and other components make for a nice contrast. Another option is one could have the aluminum anodized to the color of choice. Thermal expansion of Al is not much greater than brass.
