Mechanical WW USA vs Swiss stem sizing
Discussion in 'Watch Repair' started by Roy Horrorlogic, Aug 28, 2019.
  1. Roy Horrorlogic
    Roy Horrorlogic Registered User
    Mar 7, 2017
    384
    99
    I recently bought both a new stem and a couple of (ludicrously expensive) gilt crowns for an early Gruen Curvex. I checked the old stem size first and the threads appear to be tap 10 (1.0 mm). As is the new stem. Neither of the crowns fit, having threads approx 0.8 mm.
    A wiser man than I has told me that there's a discrepancy between Swiss and US "metric" measurements for stems. Uh?
    So what size Gruen crown do I need to find to fit this size stem? Assuming I can raise a mortgage to buy one.
    If anyone has a suitable crown I'd be happy to swap for the two I have - or buy it.
    Roy
    Barney Green likes this.
  2. Chris Radek
    Chris Radek Registered User
    Apr 13, 2014
    631
    219
    Watchmaker (now accepting new customers)
    Lincoln, NE, USA
    I wish we all had the good sense to just use mm measurements everywhere!
    If the stem measures 1.0mm with a micrometer I think that's generally called tap 9, not tap 10. This might be your error?
    Although I can't find confirmation right now, I think I have seen two "tap" scales for stems/crowns where one increases tap number with increasing size, the other increases tap number with decreasing size (which is the commonly used system). I would not be surprised if there were a good handful of systems over the years/countries.
  3. Roy Horrorlogic
    Mar 7, 2017
    384
    99
    I should have added the word "nominal" to the figure of 1.0 mm. Measuring with a caliper the diameter is a little over 1 mm. Which, I assume, relates to the relative diameters of outer and inner thread. The crowns fit a test stem which measures a nominal 0.8 mm.
    Does this clarify the problem?
    Roy
  4. Al J
    Al J Registered User
    Jul 21, 2009
    613
    69
    Can't recall where I got this from, but it may help. To resolve the issue you have, you can either get a stem with a different thread is it's available (some companies offer more than one tap size) or you can use a stem extender that also converts one size to another...or of course get a different crown.
    Cheers, Al
    viclip likes this.
  5. Roy Horrorlogic
    Mar 7, 2017
    384
    99
    Thanks Al
    i have lots of extenders but the movement and case only allow very short threads so that's not an option.
    That chart is, to put it mildly, very odd. If the intention was to ensure confusion it couldn't be improved upon. I have a huge number of miscellaneous crowns so sizing has always been a matter of "which one fits". But in this case I'd like to put a Gruen signed crown on the watch. Nothing is easy...
    Roy
  6. Barney Green
    Barney Green Registered User
    Jan 19, 2017
    69
    34
    electronics engineer
    Diesel gate HQ
    Hi Roy,
    if you get a Gruen signed crown for this watch it might not be original. We discussed this in another Gruen forum and it turned out that it looked like that the crown of the early Curvex watches were not signed. It would really ne nice if we could either find original signed crowns for these stems or even better, a NOS watch which should have the original crown.
    Barney
    Roy Horrorlogic likes this.
