US import codes - from when?
trim
Feb 19, 2010
151
Does anyone know when these codes were first brought in? I am sure I have read this somewhere, but after much searching have failed to find it again.
mike184
Feb 11, 2010
54
Hi!
AFAIK the import codes have been used from the 1940s to the 1960s, but I don´t know the exact dates. Maybe s.o. else?
Cary Hurt
Dec 16, 2005
2,421
I'm pretty sure they were a requirement of the Reciprocal Trade Agreements act of 1934. Don't know when the requirement was dropped.
trim
Feb 19, 2010
151
Thanks!
Is is at all possible that a watch without an import code, but marked unadjusted would be from before this date? I have a few like this. I very much think of 'unadjusted' as being a US phenomenon along with the import codes. But I don't know if the two markings were separate requirements or came in together.
mike184
Feb 11, 2010
54
AFAIK, it came at the same time. I´ve seen many movements with "unadjusted" and without an import code, but I´ve never seen a movement with import code without "unadjusted".
Of course, most of the movements had been adjusted though, they just had been marked in that way to lower the import tax. The best I´ve seen was a Rado 56-H with certified chronometer-movement and "unadjusted" on it. :D
Mirius
New User
May 7, 2011
I've got watches which are marked unadjusted and which I have no reason to think have ever been near the US. Whilst I agree the intention of 'unadjusted' is for the US, the question is who marked them with the import codes? The one on your site trim has clearly been done by hand and so I'd be surprised if that was at the factory. Unadjusted however is clearly a factory marking, so more likely that it was done to batches of watches some of which might end up in the US?
trim
Feb 19, 2010
151
Yes I agree, I was just flying a kite. It crashed.
I'm taking 1934 as a lower bound for watches with the code.
Also, that 264 you are talking about, the unadjusted is engraved the same way as the FXU code and FIFTEEN JEWELS are done. Obviously all required together and added afterwards. I do recall the need to spell out the number of jewels on US watches.
Roland Ranfft
Feb 10, 2011
687
12
Wildenrath, Germany
www.ranfft.de
Hi trim,
Indeed, what else than bureaucratic idiotism makes people scratching the jewel number manually into a small scale produced movement:
But this was obviously prior to the invention of import codes. There was none, but in turn the responsible manufacturer scratched into the plate (like the jewel number).
Regards, Roland Ranfft
Cary Hurt
Dec 16, 2005
2,421
I believe the handwritten codes and jewel notations generally date from the 1945-1950 period, when the US market was seeing unprecedented demand coupled with a slow response from the traditional domestic producers. As more importers looked for sources of movements to sell in the US, many movements that had been unmarked (as they were intended for European use) were diverted to the more lucrative American market. The codes were then quickly "hand done" to meet the US import requirements.
The handwritten names are almost always the names of those third party importers that were so prevalent during this period.
trim
Feb 19, 2010
151
It must have also occurred when the regulations came in, or on small orders. The reason I say this is that the watch that we've discussed, the MST 264 calibre was obsolete for around 10 years by the 1945-50 period.
I have another example, that must certainly be from the post WWII period you mention, the engraving is of much lesser quality on this one.
Watch Carefully
Jun 18, 2003
30
This is the watch Mike mentioned (my watch, photo courtesy RGM despite my pesky watermark):
More info is available via the link below and in my article forthcoming in the NAWCC Bulletin Sept/Oct 2020 issue.
Rado 56-H B (ca. 1965, steel case) - Watch Carefully!!
Adam Harris
Moore NWCM Award
May 3, 2012
3,282
90
69
Costa Blanca - Spain
highercailber.com
1930 to 1969
Tomxhar
Registered user.
Sep 2, 2019
96
54
57
According to recent research, May 1st 1936 until roughly 1965.
177,601
1,556,524
53,629
nicobirdie
909
3,058
Watch Inspectors by Kent
