• Upcoming updates
Urgos 9 tube
clocker2
Nov 22, 2005
242
If you follow the power from the cable drum gear up through, you will see that power to the music wheel comes from one side of the bevel gears. This turns the music drum and the gear on the drum then drives the other side. Continue to follow the power back to the movement and up to the fly. Its a very unique way to drive the music roll. Whatever you do, do NOT loosen that set screw on the back gear with the weight on the clock!! If you do, that weight will sing to the bottom quicker than you can say, "oh darn" or something to that effect. :)
So it is not driven from both sides as one may think.
Jeff Major
tymfxr
May 13, 2005
1,202
36
I too have found that this particular movement has little tolerance for wear.
aleksey1967
Jan 26, 2008
61
Might be my questions is too late in time . I have also the same movement in very bed condition. Actually tubes is absent. Can you perhaps inform about tube dimensions and send for me couple of the photos of this movement. Do you have contact information where parts for this movement can be found. Thanks, Aleks.
Contact free aleksey1967 AT yahoo.com
18,215
3,632
These 9 tube sets are available from several suppliers.
Get ready to cough up about $600, more or less.
aleksey1967
Jan 26, 2008
61
many thanks for the information. I really intend to make this tubes, not to buy. So it would be nice to have some dimensions for such tubes.
49,686
3,032
Whatever you do, do NOT loosen that set screw on the back gear with the weight on the clock!! If you do, that weight will sing to the bottom quicker than you can say, "oh darn" or something to that effect. :)Jeff Major
I think I might have said 'something to that effect' once :eek:
R&A
Oct 21, 2008
4,218
109
No I thinks it's more to the curb of,what the &%#@+@#%%&* just happend.
179,952
1,569,764
54,328
redepicted
911
3,090
