Les Sanders
I am working on a 9 tube URGOS on the left end of the pin barrel there is Collette with long pin it will slide inside of the pin barrel what is its function?
No it turns with the barrel, my best guess is used for fine tuning chime striking?Does it move independently of the barrel?
Here is my assembled Chime Drive.So back at it today Glutton for punishment. I am going to start with removing 1. the chime drive mechaniism then 2. the pin barrel and hammer assembly. Since it won't chime and almost impossible to turn the barrel I am not 100% sure the chime drive is put together as intended!
So I am close to being done, testing, One question remains 4 Hammer settings Top equals Silent, 2 equals
So I am close to being done, testing, One question remains 4 Hammer settings Top equals Silent, 2 equals. 3 equals
4. equals
I have the clock chiming just a bit of fine tuning on the hammer force!. For me it has been the clock from Hell!Three different chime settings: Westminster, Whittington, St. Michael, then the Silent option.
The Whittington and St. Michael chimes use 8 tubes and Westminster uses just 4 tubes.
Is there any special grease you used and how much did you use on the beveled gears?I just finished restoring a similar one about a month ago and glad to be finished with it ...
The one I had used 1mm x 105" cables and had double clicks on all trains. I had to build a 6" temporary stand to let the cables run down to replace them. Lots of wear in the one I did, from bottom to top. The dual bevel gear pin drum drive is a bear to figure out. Be sure to hand clean and grease the three bevel gear faces.
Good luck, Willie X
Willie, I have it chiming with out the hammers installed. the pin barrel turns as it should and strike rack is good. What I found was every time I put the pin barrel no action, I have a spare back up movement when I installed the main shaft with one beveled gear away we go. There must be a problem with other gear. seems to be fine now I greased the heck out of those beveled gears. I will hook the hammers up Monday let you know! Thanks to all!Just a little, on faces of all 3 gears. It will spread itself out as the clock runs. I've used ENK mainspring grease, general purpose automotive cup grease, lithium grease, they all have worked well. The lithium grease will turn brownish and harden over time but I wouldn't take it off the list.
The grease you pick has to be thick enough to stay put. 'Red sticky' cup grease and 'spinning reel' grease would probably be good but I haven't tried those. Main things are that it won't dry out and using a small amount.
Thanks Mr. WillieJust a little, on faces of all 3 gears. It will spread itself out as the clock runs. I've used ENK mainspring grease, general purpose automotive cup grease, lithium grease, they all have worked well. The lithium grease will turn brownish and harden over time but I wouldn't take it off the list.
Well I hooked up the hammers and lined up the pin barrel, it will not drive the pin barrel. I loosened the pressure between the main bevel gear and the other 2 bevel gears, down goes the weight. I can only guess o clearance is the answer. What about lubeing the pinsWillie, I have it chiming with out the hammers installed. the pin barrel turns as it should and strike rack is good. What I found was every time I put the pin barrel no action, I have a spare back up movement when I installed the main shaft with one beveled gear away we go. There must be a problem with other gear. seems to be fine now I greased the heck out of those beveled gears. I will hook the hammers up Monday let you know! Thanks to all!
Well no doubt some thing I have not figured out! I now have the beveled set at 0 clearance. I have a event to go to with the wife. Have a great weekend. BYW I noticed that beveled gear set does not run smooth jumps a bit, it has a tiny ammount of play where it goes through its plate.If the weight went down, you have other problems. Willie X
Enough movement to cause binding?Well no doubt some thing I have not figured out! I now have the beveled set at 0 clearance. I have a event to go to with the wife. Have a great weekend. BYW I noticed that beveled gear set does not run smooth jumps a bit, it has a tiny ammount of play where it goes through its plate.
Mr. Willie,I just finished restoring a similar one about a month ago and glad to be finished with it ...
Good luck, Willie X
Mr. Willie,
The movement I am working on has 1mm x 105" cables on it as well , I was winding the cables onto the drum and they seem to overlap onto the cable already on the drum, is this normal? Of course this movement doesn't have any stops so I was wondering if the cables are correct are should I just not wind them all the way up until they overlap cause I have had cables get into the ratchet gear when that happens and you know the rest of the story!! Thanks for the help in advance.
Back on the original post, I am wondering about the 3 gear bevel set, is the Butterworth T 1 butter bushing intended for the center gear to address the sloppy condition of the set?The original Urgos cable was 0.8mm diameter. The 1.0 mm is used on the new Urgos made by Hermle. Butterworth Clocks carries the 0.8mm cable in stainless steel with ends to the proper length.
I figured someone put the wrong cables on it in the pastThe original Urgos cable was 0.8mm diameter. The 1.0 mm is used on the new Urgos made by Hermle. Butterworth Clocks carries the 0.8mm cable in stainless steel with ends to the proper length.
Mr. mark do you have the information on these cables so I can get some ordered.I figured someone put the wrong cables on it in the past
The original post has turned into a discussion on cables for a URGOS. I am having a great deal of trouble with the entireMr. mark do you have the information on these cables so I can get some ordered.
Tube chime movements have to be tight as a fiddle to run, no slop or play whatsoever.
You'll have to prep up a big bushing to handle that shaft so it doesn't jump around.
Have you checked the bevel gears for wear from old oil buildup? I see in your photo there's quite a bit of old dry oil inside each gear tooth.
Too much old dry oil can chew up the gear teeth, leading to wear much more difficult since it would require resurfacing many teeth.
With all things considered, this is why movement replacement is considered the norm for 'repairing' these clocks.
What Loctite are you using for that? 609 or something? The green stuff?Each numeral only needs a trace of loctite to fix them back in position and they are secure in minutes.
Too much loctite = ruined dial
Sorry to butt in. I'm starting a post on the same movement "Urgos 03038 9 Tube" Please stop by and give me some advice. DannyThe original post has turned into a discussion on cables for a URGOS. I am having a great deal of trouble with the entire
You should get Steven Conovers Chime Clock it covers the 9 tube in detailSorry to butt in. I'm starting a post on the same movement "Urgos 03038 9 Tube" Please stop by and give me some advice. Danny
