Urgos 32
Discussion in 'Clock Repair' started by MuensterMann, Mar 13, 2017.
  1. MuensterMann
    MuensterMann Registered User
    Mar 23, 2008
    891
    Did the Urgos 32 movement in 1977 use plated pivots? I am wondering to bush or buy new - it is a family clock. I read the long post on which movements has plated pivots and a list was created. However, at the end of the post I read that only Hermle movements had the plated pivots. Any factual advice would be much appreciated! Thanks!
  2. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    621
    Science teacher, writer
    Lancaster, Ohio, USA
    If you don't mind disassembling the movement, you can wipe off each of the pivots and look at them with a loupe. If there's chrome plating flaking off, then it had plated pivots. What I've been doing, heaven help me, is just grinding off the plating and polishing the pivot until it's gleaming and happy. If you've got plated pivots that are deteriorating you'll find substantial elongation of the holes for the first three or four wheels in each train. If so, you can polish the pivot in question and re-bush, or else buy Butterbearings from Mark Butterworth. They work exceptionally well.
    M Kinsler
  3. MuensterMann
    Mar 23, 2008
    891
    Did Urgos make some plated and some not?
  4. R. Croswell
    R. Croswell Registered User
    6,642
    23
    I can't answer that question but would also be interested in knowing if some makers (other than Hermle) used plated pivots that are not failing?
  5. matthiasi
    matthiasi Registered User
    Dec 3, 2010
    262
    Clock Repair & Restoration
    Kelowna
    I don't think they made plated pivots.
    I bush these movements regularly and have a good track record. Have rebushed movements from 73/74/77/79 within the last month. Escapement wheel is delicate, so watch out there. (Replacement blanks for these have all but dried up).
    I personally like these Urgos better than the Hermle's of the same vintage.
  6. MuensterMann
    Mar 23, 2008
    891
    Thanks Matthias, you provide good data points!
  7. bangster
    bangster Super Moderator
    16,311
    20
    Mark Butterworth would know for sure.
  8. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    Donor NAWCC Member
    Jul 4, 2009
    1,874
    My understanding is that all the German manufacturers eventually went to the nickel plating due to rust issues and machining considerations, but Hermle was the first. The rest followed in the 1980's. Regarding the replacement escape wheels for Urgos, we still have some unmounted originals left.
Similar Threads - Urgos Forum Date
Old Urgos gf pendulum leader missing Clock Repair Saturday at 2:18 AM
urgos erratic strike Clock Repair Aug 29, 2017
Urgos westminster chime 4182 Clock Repair Aug 19, 2017
Urgos 323 18d query Clock Repair Jul 8, 2017
Urgos leader Clock Repair Jun 21, 2017
