I have been working on a Urgos 32/1 movement. The minute hand just seemed to get tighter and tighter over time as I turned it to the point that you can not turn it yet the clock will still run. If I take the pallet assembly off you can spin the center shaft with little to no friction.
I tried to reset the pallet assembly to find a point where the clock would tick and I would be able to turn the minute hand. Once the pallet was engaged to tic tock I could not move the minute hand. Something is not right but I do not know where to look next.
